help with tuner pro
dalwine250
please bare with me ,i am computer illiterate.i have tunerpro up and running.aldl ,no ostrage.i can monitor every thing fine.my question is can i or how do i, record a run. thanks for any help. dave
WyoSyclone
Re: help with tuner pro
Hi Dave,
With the truck started, or key on, launch TunerPro.
Hit the F4 button. At the bottom of the screen that comes up will be a little box that says "connect". Click on that box. You should now see data streaming from the ECM into TunerPro.
At the top right of the screen is a series of buttons that look like those on a cassette deck. The Red Circle is the record button. Click on that and a box at the bottom of the screen will turn green and you will be recording. When you're ready to stop recording, hit the square box at the upper right of the screen - a box will pop up asking you for a comment for that recording session - I usually put in the date and time. Hit save, and you're done.
If you want to play it back, push the F4 button again and click on the pull down menu that denotes the time of the recording session, and click on the newest entry. Then you can click on the play button and your data will start playing. You can click on the 'v', 'd', 'm' buttons at the top of the main screen to bring up different modes of viewing the data.
Hope this helps,
Rob
dalwine250
gave it a try.i get data ,click on the record button and i get an error message.error creating log file.wtf ?i love computers
skwayb
NWSTP
When you hit F4 to bring up the ALDL box, look on the right side. There will be a section for the log file. You need to tell tunerpro the name of the log file you want it to save and where to save it on your computer. Once you do that, the error will go away. If you keep recording to the Same file, you will see in that same box Session #. If you want to play a different session back you will need to pick which you want to look at in the drop down box. Tunerpro will put a date and time on each session.
WyoSyclone
Hi Dave,
If you still have a problem, send me a PM... I've got my laptop here beside my home 'puter and I can fire it up and walk you thru it.
..Rob
