Hmmmm fpr??
mildtowild
Custom Upholsterer
fuel pressure is 50# with no vac line and 42# vac attached. I am assuming that the old fpr is not dealling well with the walbro. if it makes a difference i am running an autometer from the fuel rail. anything else cause this? could this be the cause of the intermitant stumbling i am getting? the plugs are a little black.
mildtowild
Custom Upholsterer
Re: Hmmmm fpr??
I know it is rich and will foul the plugs but can i drive it untill my apfr gets here?
turbodig
Re: Hmmmm fpr??
You sure you don't have one of those adjustable FPRs that had the screw inside the vacuum port?
50 psi for a stock regulator is waaaay too high.
Re: Hmmmm fpr??
X2
Drive it that rich? Prolly not. Yur risking fouling plugs to where it won't run plus washing cylinders. Maybe a restriction in the return line somewhere?
