How Much Timing Is Everyone Running?
1SYCLONE1
Hi guys, I was just wondering how much timing everyone is running. I have a fast unit and I believe that Im running16*. I was told if I put more timing into it it will spool up the turbo a little faster and cool down my under hood temps a bit. So Im not sure how much would be to much and If I should add it through out the complete tune or just part of it. I have a built motor with a 70mm turbo and Im not so sure on how to mess with the fast unit so if anyone can help walk me through it that would be great. Thanks for any and all help.
Andreas
Re: How Much Timing Is Everyone Running?
I'm in the same shoes as you, learning. I'm no master tuner but this is what I've picked up.
Were in the timing graph/chart do you run 16*, at WOT? All over the graph/chart?
What timing you can run depends on boost level, RPM, how good your tune are, what heads you have. Its also from motor to motor what you can run.
I've read somewhere 14 - 17ish at WOT for LB4 heads 17 - 23ish at WOT for Vortec's, I dont think it was reffering to stock 14,7psi, maybe 18psi.
1SYCLONE1
I have ported brodix heads and 84lb inj. I have my truck set to 28lbs of boost.
turbodig
Hope that's not pump gas.
The mount of timing you should run is specific to the heads/pistons you run, and how they're prepped. There isn't a one-size fits all answer.
Experiments with timing involve a lot of looking at plugs, or a really good method of detecting knock (or both). Either that, or you resign yourself to breaking parts to find out.
Still, 16 degrees on race fuel at 28 psi sounds a bit on the conservative side. It'll depend a lot on what grade of fuel you're running.
28 psi sounds like a lot... how did you arrive at that boost level? Just because a turbo can make 28-30 psi doesn't mean it's going to work well there.
1SYCLONE1
I have an a different block and built motor. Hell you have to booooooost these little v6's to make power. LOL. Thanks for all the help.
turbodig
Doesn't matter what you built it out of... You can buy full custom pistons, Olivers, Bowtie block, billet crank. If it detonates, it will die.
I've seen lots of really well built motors that pounded the bearings out of them, screwing up a crank and usually more than one rod in the process.
My .02.
1SYCLONE1
My .02.
I totally agree with you.
