bender
I drove the truck to work, everything was fine. I started to come home tonight, let it warm up and then started home. After about 2 miles I stopped at a stop sign and when I went to take off, it stumbled as I gave it some gas. Then it was fine but the check engine light came on. I looked at my autometer boost gauge and it was stuck at 0psi. I pulled into a parking light to check if one of the vac lines came loose and they were both fine. So I drove home and checked the mail and lucky for me the aldl cable Mr Rockwell is lending me was there so I ran inside to get the laptop.
I hooked the truck up and did a monitor and it was throwing only code 43. I pulled the ecmb fuse for a coupe minutes while I searched code 43. Anyhow I replaced fuse and fired the truck back up. No code, so I took it for a little drive down the road, The thing I dont get is the knock count was 2518 at idle and stayed there for most of the drive with knock retard staying at 0.0, I got on it twice to about 3500rpm, the first time nothing changed, the second the knock count went to 2855 and stayed there till I shut it off, when it jumped it pulled 1.5 degrees of knock retard. I dont know if I am getting reliable data.
I downloaded the trial of datamaster, it says the 91-93 4.3l turbo under about, so I think its right. It only says my target boost though is 6.5psi.
