Innovate Lc1 wideband controller
syclone rider
Re: Innovate Lc1 wideband controller
I'm not but would like to switch to the lc1 as well with code59 if possible?
Its possible but im having a problem getting the gauge to read right the datamaster run at idle its saying its 14.7 but my gauge is only reading 9.9 to 10.00 cant figure out whats going on i really need some help if anybodys running it with code59 to know what color wires they have running to their ecu.
TYTILIDIE
METH HEAD
You need to tell us how you have it set up and what you want it to do. How did you program it?
syclone rider
It is setup and programmed to run with code59 i have analog 1 ran to B9 on the ecu and analog 2 ran to the F14 on the ecu.Like i said before i logged a dm and at idle the dm said the wideband was reading 14.7 but my gauge never moved from 9.9. I have calibrated it twice and programmed it twice.
TYTILIDIE
METH HEAD
Analog 1 is yellow and goes to f14. B9 is green and or white wires (ground, specifically white=system ground and green = analog ground). Brown analog 2 runs to E14. I may have E and F 14 backwards. Physically it's like this : purple o2 wire should have the yellow analog 1 tied in to it. The opposite pin of that, gets the brown analog 2 wire, it is blank. If you need anything more, I can take pics of my set up.
TYTILIDIE
METH HEAD
Of course, this set up would be if you are leaving out stock narrow band and simulating.
syclone rider
I would love to see some pics if you wouldnt mind i believe i understand what your saying but im more of a visual learner :tup:
s_blazin
i just picked up a summit kit that includes the innovate lc-1 and a summit brand gauge as well as the cd, apparently with that program you can log runs instead of using datamaster?
http://www.summitracing.com/parts/SUM-G2995/
i've never messed with one before and haven't opened the box yet to read the destructions. i'm also thinking of running code59 along with it.
i'll leave this back to the guys who know what they are talking about :tup:
TYTILIDIE
METH HEAD
Yeah you can datalog your afr's with it but still as a datalogger, NOTHING beats Datamaster IMO. Sorry bout the pics, it involves me fishing my harness out of the glove box, I'l try and get it tonight for you.
syclone rider
thanks man i would really appreciate it and sorry for you haveing to pull the harness out.Did you run the harness through to the glove box?
nello
TYTILIDIE
METH HEAD
No offense, personally, I don't care for that wiring diagram. I think it is very confusing and doesn't really tell you much. It says absolutely nothing about the ECM or is VERY unclear. I'll make one hedre that will be easier to understand.
TYTILIDIE
METH HEAD
I figured I should post my diagram since I opened my big mouth, hopefully it makes sense to you.
hrodgmc
See what afr W/B commands in open air. LC1's are known for going bad if you look at them wrong.:rotf: LM1's and LM2's are 10x more durable.
you can also take a butane lighter and see if afr goes to 18-21;1 afr, IIRC
syclone rider
It better not be bad i came right out the box bad then.
