Innovate Lc1 wideband controller
TYTILIDIE
METH HEAD
Re: Innovate Lc1 wideband controller
Did you ever get this working right? Here are those pics, hard to tell what is what though
syclone rider
Nope i have been threw hell the past 2 weeks last week was passing three kidney stones and trust me one is plenty much less 3 that took 5 days to pass them then i get a major sinus infection that lasted another 5 days so my past 2 weeks has sucked balls!Ok now back to the wiring so pretty much 3 wires go to the ecu 2 go to a pin by their self and 1 ties into the o2 wire on the ecm which is that purple wire with the heat shrink on it in the pic right?
TYTILIDIE
METH HEAD
Depending on how you do it. I have both system and analog grounded together in the ECM. You can ground the system ground elsewhere. But other wise, yeah. Keep in mind, I tied my green and white in to one wire that leads to B9.
syclone rider
Ok my controller doesnt have a green so i just sent the white to ecu b9 is that going to be the same as what you did or what?
syclone rider
Ok im done and that fixed the problem i was having!Thanks to everyone that helped.This is the greatest forum!
TYTILIDIE
METH HEAD
Yes you can just send the white wire there.
Glad we could help out.
Mike, thanks for helping syclone rider. I am going WB soon and learning from challenges other folks run into helps a ton.
See what afr W/B commands in open air. LC1's are known for going bad if you look at them wrong.:rotf: LM1's and LM2's are 10x more durable.
you can also take a butane lighter and see if afr goes to 18-21;1 afr, IIRC
Any reason why the LM1 is more reliable? I need to buy two WBO2 setups here soon and I'm torn. Seems like some guys like the PLX over the Innovate (thread where I ask for WB buying advice: http://www.syty.net/forums/showthread.php?t=75557).
I had considered the LM1 so I could switch back and forth between vehicles but everyone poo-poo'ed that idea because I would have to pull out the sensor if I wasn't using it or it would burn out... ugh.
turbodig
Even if you did have to pull the sensor, it's still more flexible than the LC-1 in that regard.
An LM-1 with the plug-in terminal cable can log MAP, RPM, etc on *any* vehicle. We've got one in Jim's Lt-1 Xtreme such that we get data from the Innovate software and DataMaster at the same time.
The LC-1 has had a shaky reliability history in the past. Not sure if they got around the issues, but that's why people here avoid them.
I haven't heard (or had personally) any issues at all with the PLX units.
And, a note regarding wiring....
Don't ground *any* wide-band heater or main ground to BB9 on the ECM. Only the analog or vout grounds should use BB9 as a reference ground.
Grounding a wide-band heater at the ECM is basically asking for weird noise problems at the ECM.
O2 heater grounds switch lots of current on and off rapidly, and that will pull the overall system ground around if you wire it up wrong.
Also, Innovate recommends in numerous places *not* grounding the ground wires in the same place.
This is because of the noise issues above. It's best to get the heater or main ground as far away from the ECM and as close to the battery as you can get it.
syclone rider
Let me start out buy saying F a innovate lc1 wideband i wouldnt take one if somebody gave me one!Had a brand new one worked for about a week!WTF Thanks to craig moates i sent it back to him and hes sending me a new PLX.No calibrating and no resetting.So if you ask me PLX wideband all the way!
It's just a six
Super Member
I have had my LM1 for 7-8 years or longer & works great ,never had to even recal it on my Sy,I just leave it hooked up to my Sy & drive it.
syclone rider
Yeah i have heard that about the Lm1.I didnt do my homework good enough before i bought the lc1.Ill never make that mistake again!
