Re: Innovate Lc1 wideband controller
Mike, thanks for helping syclone rider. I am going WB soon and learning from challenges other folks run into helps a ton.
Any reason why the LM1 is more reliable? I need to buy two WBO2 setups here soon and I'm torn. Seems like some guys like the PLX over the Innovate (thread where I ask for WB buying advice:
http://www.syty.net/forums/showthread.php?t=75557).
I had considered the LM1 so I could switch back and forth between vehicles but everyone poo-poo'ed that idea because I would have to pull out the sensor if I wasn't using it or it would burn out... ugh.
Even if you did have to pull the sensor, it's still more flexible than the LC-1 in that regard.
An LM-1 with the plug-in terminal cable can log MAP, RPM, etc on *any* vehicle. We've got one in Jim's Lt-1 Xtreme such that we get data from the Innovate software and DataMaster at the same time.
The LC-1 has had a shaky reliability history in the past. Not sure if they got around the issues, but that's why people here avoid them.
I haven't heard (or had personally) any issues at all with the PLX units.
And, a note regarding wiring....
Don't ground *any* wide-band heater or main ground to BB9 on the ECM. Only the analog or vout grounds should use BB9 as a reference ground.
Grounding a wide-band heater at the ECM is basically asking for weird noise problems at the ECM.
O2 heater grounds switch lots of current on and off rapidly, and that will pull the overall system ground around if you wire it up wrong.
Also, Innovate recommends in numerous places *not* grounding the ground wires in the same place.
This is because of the noise issues above. It's best to get the heater or main ground as far away from the ECM and as close to the battery as you can get it.
