bizkit
bonofied SyTy junkie
Ok I feel bad about adding another wbo2 thread but I've read and read and wrapped my head around this thing all weekend and can't figure it out. So here it is and I need some help from you guys. This is all using code 58.
I got the tuning package from Detroit Turbo with the PLX SM-AFR wbo2 kit and I installed everything, it went pretty smooth. I'm using Tunerpro with the Moates Ostrich and can datalog/emulate no problems with a stock BBZB$58 bin. I have used Digs' patcher with the PLX 300/400/500 patch file on this bin and it seems to create a good .pch file, then I rename it as a bin file.
When the truck is running on the stock bin I load the patched file into Ostrich and nothing seems to change, no AFR window pops up or anything like that. When I shut the truck off and start it with the patched bin, it idles high ~ 2000 rpm and seems a bit rough, and the check engine light flashes on/off quickly and still no AFR window. It does this with either a 2 bar or 3 bar map sensor installed. With the truck idling high and rough I load the stock bin back into Ostrich the idle comes back down to ~ 750 rpm, the check engine light stays off and everything seems normal (This happens instantly).
On the ecm pins with everything connected and the truck running the stock bin, the voltage between F14 (wideband o2) and B9 (ground) is 2.4 VDC, voltage between E14 (narrowband o2) and B9 is 0.4 to 0.5 VDC.
Two small capacitors came with the wideband kit and I installed one between F14/B9 and one between E14/B9 as per the instruction manual as close to the ecm as possible to cancel out electrical noise. On the PLX there is an analog output with four pins: ground (b9), wideband (f14), narrowband (e14), and a 3.4 Volt that I have no idea what it's for and I didn't hook to anything.
Am I missing something? Any thing else I can try to help troubleshoot this? I don't have an external AFR gauge but I will have to get one if I can't get this patch to work. I'm not looking for handouts but does anyone have a stock 3bar patched bin I can try?
