Is there A computer out there that controls everything?
1madgumby
Wondering if there is A computer were you can just plug or wire it in & it will set all air to fuel ratio's automatically adjust it self to A 14-1 ratio from idle to 100%WOT?
Aj
turbodig
Re: Is there A computer out there that controls everything?
And furthermore, a 14:1 ratio at WOT would = death.
The FAST has a 'learn' key... you keep hitting the key, and whatever cell it happens to be in, it'll try to achieve the AFR that's in the corresponding cell in the AFR table.
In addition it (and other ECUs as well) do a WOT "slow trim", where they'll try to hold AFR to the target in real time. In order for this to work properly, your VE table needs to be fairly close.
This assumes, though, that your AFR table is correct... which it isn't, necessarily, since every vehicle responds to a different AFR profile differently.
It would be ill-advised to have an ECM control everything. For one, there's no way it could know whether the vehicle liked the changes it was making. Also, if a sensor or connection was bad, the information it would get was bad... leading to bad changes and *BOOM*.
What you really want, is a good tuner. The money you pay them to get your setup dialed in will be much less than what you spend chasing issues and breaking parts due to a bad tune. You need to find somebody with actual SyTy experience, not any garden-variety "tuner".
AJ, you kept trying to find the "easy" way out. You added a lot of nice parts, and a lot of hard work building what you have. Go the extra step and learn the tuning process, or find someone you trust to do it.
You know where I live if you want to bring it this way on a trip to visit your mom. Of course we are glad to help as much as possible over the net. Your idle should be somewhat close now.
