Re: Keep beaking wheel studs
No idea about the wobble unles you have a bent axle somehow.
I have always been told to mount and index the spacer to the mounted rim and tire then have the whole thing balanced.
A lot of imbalance will work the bolts loose. Good to here you got it worked out.
Hub centric is the best way to go ...but not always possible.
TYTILIDIE said:I use what you are talking about. So far, I haven't had any issues yet since I had them fixed again. It has involved about a week of re-torquing. Had to check them every day. My ultimate solution is going to be to get a different rear end to eliminate the spacers altogether. One thing I notice, is that my rear wheel wobbles on the spacer, not sure if the wheel hub is bent or the spacers suck? Ill figure it out on of these days soon here.
