Knock count without starting engine?
crashing_sux
Blow Me?
I'm getting some pretty severe false knock. At idle my knock count seems to count up to around 64k and roll over back to zero so it looks like it's count up to around 60,000 every few seconds. If I put my truck in park and rev it even slightly I start getting knock retard, pulling 18 degrees of kr with a few thousand rpm in park.
I tried shutting my truck off then turning the key on as I was going to tap my intake to see if I could register knock properly with the truck not running but found that just turning the key on (without starting my truck) showed around 2500 on my knock count.
Should that even be possible? What exactly is knock count measuring? Is it how many detonations the sensor thinks it has heard of it it just some sort of baseline background noise number?
I've read about 30 posts on false knock and it looks like this could be tough to diagnose but I haven't read one yet where someone is showing a knock count before they have even started their truck.
crashing_sux
Blow Me?
Hmmm.....that's a possibility. I'm running on an emulator. I didn't buy a chip burner yet, figured when I got everything working properly I'd then burn a chip but that may be months away. I know there are plenty of other people running of an emu but maybe something is a bit off with mine?
I could pull the emu and re-seat it but if the problem is with the emu itself I'd have no way to find out. Maybe I need to have someone burn me a chip so I can plug it in and test it?
Come to think of it, I do have a 40lb chip that I wouldn't start my truck with but it would be enough to turn the ignition on and see if I was still registering a knock count.
crashing_sux
Blow Me?
I just verified with my 40lb chip and multiple bins that any bin I load with the emu causes the knock count to read between 2535-2539 with the emulator and 0 with a chip.
I'll email Craig Moates and hopefully he can fix me up. Until I have a real solution does anyone know of a flag I can set to disable knock retard for now? Obviously I wouldn't build any boost like this but at least I could still drive to work and back. If not I guess I could just adjust my maximum knock retard to 1 degree.
crashing_sux
Blow Me?
Yep, which is why I won't start my truck with the 40lb chip. I have 40lb injectors as well which I have no use for, and 72lb injectors in it currently.
Seems like this emulator is injecting interference into my ecm causing it to sense knock when there isn't any (I'm 99.9999% sure my engine doesn't knock while not running) so I emailed Craig asking him if he's seem this issue before and has a fix. Maybe I just got a bad emu, whatever the result I'll post back here when I find out so the answer is documented for the next guy lucky enough to run into this.
