crashing_sux
Blow Me?
I'm getting some pretty severe false knock. At idle my knock count seems to count up to around 64k and roll over back to zero so it looks like it's count up to around 60,000 every few seconds. If I put my truck in park and rev it even slightly I start getting knock retard, pulling 18 degrees of kr with a few thousand rpm in park.
I tried shutting my truck off then turning the key on as I was going to tap my intake to see if I could register knock properly with the truck not running but found that just turning the key on (without starting my truck) showed around 2500 on my knock count.
Should that even be possible? What exactly is knock count measuring? Is it how many detonations the sensor thinks it has heard of it it just some sort of baseline background noise number?
I've read about 30 posts on false knock and it looks like this could be tough to diagnose but I haven't read one yet where someone is showing a knock count before they have even started their truck.
