L35 tune????
slpcamaross97
Looking to do a L35 head swap with 1.5 RR, just with a little porting and cleaning up.
truck has intake, cat back, and NO cat.
DO I NEED A TUNE TO BE SAFE?
Re: L35 tune????
A stock truck needs a tune, so any mods will still need a tune in my opinion.
turbodig
Re: L35 tune????
Honestly, if "safe" is your primary goal, leaving it as stock as possible is your best bet.
If you want it done right, without having it detonate itself to death somewhere down the line, you'll get it custom tuned.
Putting it bluntly, anyone who sells you a chip based on a phone conversation, and tells you that it will work with your setup is lying to you. Anyone who sells you a used chip that was in their truck and tells you it'll work fine in your truck, is lying to you.
Ty 1885
Re: L35 tune????
Alot of people using Code59. I myself did not have the pations to learn it , and went with FAST XFI.
It is very expensive, about $2,000 plus you need a adapter harness. FAST is alot easiar to tune.
If your going the FAST way, DONT buy a adapter harness from Caspers !!! I and others had nothing but problems with them.
I cut the OEM harness plugs and used FAST scematics to wire it up. Works great.
