Re: LC-1 "Extension Cord"?
The LC-1 use the same cable as the LM-1? If it does. This is what I did. When I got the Mustang dyno. The LM-1 they put with the computer, came with a 12? ft cable. I called Innovate. They told me I couldn't use anything longer and that was all that would work with the box. Or the readings would be way off. Well. I went to Radio Shack carrying the LM-1. Got a cable, and an adapter. I have three spare 6 ft cables and adapters. We have tested the wideband against others that were on various vehicles both with the standard cable then with the "extensions". They read the same. Probably 8,000 dyno runs later, most with the wideband hooked up. I still tune with them if needed, depending on the car size and exhaust exit location.
Have had tuners come in from around the country. Nobody has ever thought to use the cable like I did. And are amazed at how well it works.
