Lean cruise AFR's
SBNova
I was wondering if anyone here has played with lean AFR's in a cruise setting? I have been reading over at TGO about lean cruise mode, where the ECM leans the mixture and adds timing to get better MPG. ( I understand this may be a feature upcoming in $59)
The stock $58 code we use doesnt have this mode, but since I am running code $59 in closed loop wide band, I am able to command AFR's vs MAP and RPM. I tried 15.3-15.5 and I dont think I saw much gain in MPG. I read over at TGO that some guys are running much leaner.
Glenn91L98GTA wrote-
I found 17.4:1 and 47* total spark gave me my best fuel economy with a stock L98 TPI car. Play with your AF & spark and take some LONG highway trips. The best I ever I ever got was 385 miles on 12.9 US gallons using the combo above. I tried a gazillion combos and drove 100,000 miles testing it. The AFR & spark that I mention above gave me the BEST mpg. Oil temps were never a problem. I never burnt out my cat.
Fast355 wrote-
My TBI 305 VAN will tolerate 16.7:1 and about 44* total spark on 93 octane in OD w/3.73 gears and P295/50/R17s. That just tells you that you can get pretty aggressive at part throttle cruise without hurting anything. Just watch for the warning signs of detonation and high EGTs and you will be fine. The engine will let you know when you push it too hard, before it blows up, usually in the form of a lean surge.
How lean has anyone here pushed a SyTy, or turbo/SC combo??
I am thinking about getting much closer to 16:1, if not slightly leaner. Damn I need a co-pilot so I can tune while the Ty is driven !!
leroy
Re: Lean cruise AFR's
Fast355 wrote-
I've gone over 16:1. If you have a place to long flat place to test it, maintain a contstant cruising speed, then continue to lean it out until you need more throttle opening to maintain the speed. It does help to have a copilot.
Jim
UR50SLO
V6+2=LSXCamaro
That ends up being close to 30mpg... nothing wrong with that..... :tup:
The bucking and surging will let you know when your too lean.. as mentioned above.
I can't wait to learn more about tuner pro tomorrow and Saturday at the nats!
~Scott
turbodig
Tire balance can give you 1-2 MPG, also. Need more air in the fronts than you do in the rear.
sytyguy
Moderated User
Funny you should mention it. I did a test some years ago with my truck to see how much drag the driveline was seeing with incorrect pressures. Details below:
The Test
I found 2 mailboxes on a long straight road with no traffic (I live in BFE, so these are EVERYWHERE). These 2 mailboxes don't have to be an exact distance apart, just a good bit (say 1/8 or 1/4 mile apart). I got up to 50mph and at the first mailbox, I let off the gas. I coasted until I reached the 2nd mailbox, at which time I recorded the mph by gauge and DM. I changed tire pressures (more in front than rear) until I reached the highest speed at the 2nd mailbox. I did about 8-9 different pressures/tests.
The Results
On the first test, I was at 28 mph when I passed the 2nd mailbox. This was with 32 psi in all 4. Next, I tried 2 psi more in front and 2 psi less in rear. Speed at 2nd mailbox was 29 mph. This told me that there was indeed less stress on the drivetrain and the truck was coasting easier (but I was skeptical that it could have been driver error - letting off a little late). I kept doing tests and getting a little more speed, until I tried 37 front/28 rear. At this pressure, I passed the 2nd mailbox at 34 mph....a 6 mph difference from test 1. I tried more in the front and less in the rear, but it started slowing back down at one point.
My pressures may not work for other trucks as I have reduced the weight of the front end substanitally, difference in tires, difference in wheels, etc....The trick is finding what works for YOUR truck. I didn't leave the pressure this varying (I raised the rears to 31 psi for daily driving.), but it shows the degree to which proper pressure can help.
Hood
SBNova
So why did you lower the pressure in the rears? Did you test with the rears at the recommended pressures, and the fronts higher? I always thought higher pressures reduceded the footprint thereby reducing contact and drag. My tires are Goodyears, and they have a recommended pressure of something like 42psi. I check all my tires often, I just can remember what the exact pressure for the Ty's tires are offhand. I keep them at the max pressure printed on the sidewall.
sytyguy
Moderated User
I can't remember what tires those were, but my new ones like more pressure. I guess those old ones had a stiffer sidewall. The object is to get the rolling diameter as close possible between all four and with the extra weight of the front end, it needs more pressure. I would imagine that (in my example) a 9 psi difference in F & R would've netted similar results regardless of the pressures (to a reasonable extent). I just chose the most neutral range. Any higher on the front (to achieve a higher rear psi) could've caused abnormal center wear on the front tires. I wasn't willing to chance that.
I've always had excellent wear patterns with the reduced rear pressure. Currently (with Ecsta 711s), I run 32 rear and 39 front. I only go over 40 for autocrossing. Take if FWIW and try your own.
Hood
SBNova
Ive heard the nitrogen claims too. My local TV news did a small bit on it two months ago, and they interviewed someone who said one of the main benefits of nitrogen is that it leaks out of the tire at a much slower rate- thereby keeping your tires properly inflated longer.
If thats the case, then its not worth $7 per tire to me.
I just looked, and my recommended max tire pressure is 44 psi. on my Goodyears.
UR50SLO
V6+2=LSXCamaro
Sometimes it's the simple things that make a big difference! :)
Good info!
~Scott
