leans out with fp raised
cloneman315
i was helping my friend last night with his truck ,stock motor,50 inj and 52 turbo,this is weird but as i raise the fuel pressure u can watch the wbo2 lean right out and then motor hunts searches and dies,also how we set it,we turned the key on and set to 50 psi put vacum line on fpr and the fp falls to 38 psi ,squeeze fpr hose and fuel pressure rises but the wbo2 leans right out and it stalls wtf?any ideas,the regulatot seems to be working we have a gauge right on the fuel railand when u turn in the screw fp goes up and when u unscrew it the fuel pressure goes down,but show backwards on the wbo2.
gjp
another post whore
Re: leans out with fp raised
mine did the same thing. I dont get it either. At 45lbs it was lean. My truck likes 38lbs wih no vac atached. It idles at 34lbs with vac on and shows 14.2 on the wbo2. At 45lbs it was stalling and showing 16-17 on the wbo2.
cloneman315
yes same thing i called phill tonight and i think he thought i was drunk lol any ideas?so what did u do leave it ?
gjp
another post whore
I left it at 38lbs with no vac attached. I figured the wbo2 does not lie.
were you drunk? :rotf:
gjp
another post whore
Hmm...Me two. Picked up a case but did not open it yet.
turbodig
Watch the scan tool when it happens (while turning the screw)... I'm betting your MAP changes when you turn the screw. Suspect bad FPR.
Also, watch battery voltage while you turn the screw... if it drops significantly, that' ll cause an AFR drop as well.
What most people don't realize is that a 10 psi fuel pressure bump will only move AFR by .1-.3 at most.... it does little to the actual overall AFR. Most trucks are off by 1.0 to 2.0 lambda... a .2 change is a drop in the pond. Gotta change the chip to have a significant effect on the tune.
