Lifter ridge a problem when installing HO camshaft?
Tooky
Serious about performance
When I ordered my custom camshaft it was brought to my attention that since I'm installing this on a 60k factory block, the roller lifters may have developed a ridge. The new cam will lift at least .150" more than the original (which isn't saying much, ha) but certainly enough to make the lifters ride over the ridge, if there is one... (I haven't pulled the motor apart that far yet).
Anyone have experience with this? How likely is this to be a serious problem?
Here's what mine looks like so far. Seems clean enough that hopefully I dont have a big ridge :oops:
Re: Lifter ridge a problem when installing HO camshaft?
I would be more worried about the higher spring pressures, putting additional pressure on the lifter and having them fall apart. I have never heard anyone have ridges on their lifters, I have seen guy with SBC install and reuse lifters on 100k+ hydraulic roller lifters.
turbodig
Simple check, pull a lifter, and run a fingernail up and down in the bore. Anything significant enough to be a problem, you'll feel.
If it's been maintained well, I don't see it being a problem.
I'd definitely buy a good set of lifters... put it together right, the first time.
My .02
Syclone#892
Hey Josh I wouldnt worry about it. Actually this is the first time I have ever even heard about that. There are a lot of trucks running around that I doubt anyone checked them and I havent heard of anyone having to have a machine shop fix a lifter bore on one of these trucks. Plus you have pretty low miles which should help out.
Just a side note since you say you dont/havent done much engine work I figure I would tell you this.
Whenever I am doing a project I look at the last piece that needs to come off, for you it sounds like heads/cam. I then remove everything that is in the way of me taking those pieces off. For instance you took the intake off I would have removed the front brackets etc because it opens up the area so you can see and your not working around everything. Brackets etc are the last thing I would put back on and I even leave them off sometimes and start the truck just to make sure everything is working and nothings leaking etc.
Just figured I would mention in case that would help out, I've been working on car/trucks way to long and thats how I always do it. I hate working around something and cutting myself or something.
Good luck with the project and if you need any help just email or pm.
jwaller
Evil Genius/SyTy Guru
you will not have any ridges. the factory lifters sit out of the lifter bores. it's not like cylinder bores where the rings are down 100-200 thou from the top. you will need to replace your lifters,pushrods and chain anyway so no biggie.
