Long crank starting
sy#2921
BAMF
Here is a weird problem that I have had with the truck ever since I did a master cutoff switch.
If the cutoff is thrown to kill power the truck will not fire up like normal. I will have to let it crank 3-4 different times before it will catch and run. No matter how long or short it will not start until the 3rd try and sometimes the 4th.
However, the truck can sit for a month or more and as long as it doesn't loose power it will always fire right up the first crank cycle I give it.
Computer has a G1 adaptor, known good BBZB memcal and it happens with both my ostrich 1.0 and 2.0. The ecu relay power mod did nothing and adding extra grounds did nothing.
Any ideas?
sy#2921
BAMF
Re: Long crank starting
Exactly who I wanted to get an answer from.
I know the blm is reset but what exactly do you mean by voltage? Using a multimeter I see within .2 volts of battery/cranking voltage at the ecu at all times. Cranking voltage does not drop much below battery voltage as long as the battery is fully charged.
800+ CA battery with 0ga ground and 0ga power feed. 6ga power from alt to switch
