sy#2921
BAMF
Here is a weird problem that I have had with the truck ever since I did a master cutoff switch.
If the cutoff is thrown to kill power the truck will not fire up like normal. I will have to let it crank 3-4 different times before it will catch and run. No matter how long or short it will not start until the 3rd try and sometimes the 4th.
However, the truck can sit for a month or more and as long as it doesn't loose power it will always fire right up the first crank cycle I give it.
Computer has a G1 adaptor, known good BBZB memcal and it happens with both my ostrich 1.0 and 2.0. The ecu relay power mod did nothing and adding extra grounds did nothing.
Any ideas?
Any ideas?
