Low Temp. "Marine" T-stat's?
James Thomas
"NO CLASS"
Ok did a search and turned up a few post on PN's and places to look for buying the low temp. T-stat's but didn't really find any info on what the results were (or problems) as far as good, bad or ugly? Any one runing one or have actual knowledge of there use. Retune required, pro's vs. con's etc?
Thanks!
___________
James
ashman
Re: Low Temp. "Marine" T-stat's?
i have a 160 that seems to open too soon (around 155). in cold weather (sub 50's), the water temps hover at around 147 (that's without fans). this just happens to be the same temp that the torque converter locks/unlocks. this alone would require a chip change to lower the tcc lockup temp. i'm going to put in another 160 and hope for tighter tolerances. someone should come up with a electric thermstat.
turbodig
Thanks!
___________
James
It'll definitely cause fits with the TCC on a stock cal. There's also quite a few things that should be retuned to match the t-stat.
Later,
Black Knight
I Glow Therefore I am
I've got a 160* and with a scan tool ( not the factory gauge :tdown: ) it will usually gets up to and stays right at 160* I may get a little higher from time to time, but i've never had a issue with it being too low, since mine stays high enough I would guess why i've never had any trouble with my TCC lockup. No real problems i've seen yet, only differnece I really noticed was you can feel the underhood temp is lower, I never checked the IAT's before though so I can't tell you exactly how much.
James Thomas
"NO CLASS"
I'm not worried about the temp being to low cause it never gets below 85 or so here and re-tuning is not a problem. I do want the lower under hood temps and added performance if it's there there to be had. I have just never thought of a lower than 160 T-stat till now? Any other thoughts?
__________
James
James Thomas
"NO CLASS"
Are there and ill effects to going with the low temp. T-stat's? Who's running one?
________
James
