Re: man. boost controller (?)
i understand what yous guys are telling me, loud and clear but what you are saying about low>93 oct.(18psi) and high>meth/alky(25psi) raises a whole new question for me.
what is or should be the boost psi. cut off for 93 oct.? on my last track run i got into the low 20's but no where near 25psi. 21-22psi. to be exact. even then i thought i was pushing it to the limit. i can not even think of going 25psi.
Well, first off 18 psi may be on the high end, depending on what your setup is like, but DM or TP will tell you that for sure. I generally don't get much past 16 on pump gas, but it varies from one area of the country to another and from summer to winter.
Stock overboost cutoff was ~15 psi for more than 2 seconds sustained (ie, it had to *stay* above that) on all the stock calibrations. Most of the aftermarket chips removed this limitation.
Any of the 3 bar chips have the ability to set a fuel safety cutoff at any boost level up to about 28 psi. I'm kinda surprised more people don't use this, as it would save a lot of motors.
What it'll run on meth/alky depends on how good the chip tune is. Again, DM or TP (KR) will tell you if you've gone too far. Some are in the low 20s, others are in the mid 20s. Others higher.
