SacDoug
I am still hunting down my irratic idle issue as part of my quest to pass smog. I am using my multi-meter to check sensor voltages now.
Are these readings normal for a 2 bar MAP?
Ignition on but engine off reads 2.38 Volts.
Engine idling reads .6-.8 volts
I looking at chat C-1D of the repair manual and it gives reading using a scan tool for 3.8-5.5V for the 1st check. The 2nd check is supposed to be 1.2-2.3 Volts lower than the 1st.
Does the scan tool read a higher voltage than the actual sensor reading? Am I reading a misprint or is my MAP sensor bad?
