MAP Sensor Reading Good or Bad?
SacDoug
I am still hunting down my irratic idle issue as part of my quest to pass smog. I am using my multi-meter to check sensor voltages now.
Are these readings normal for a 2 bar MAP?
Ignition on but engine off reads 2.38 Volts.
Engine idling reads .6-.8 volts
I looking at chat C-1D of the repair manual and it gives reading using a scan tool for 3.8-5.5V for the 1st check. The 2nd check is supposed to be 1.2-2.3 Volts lower than the 1st.
Does the scan tool read a higher voltage than the actual sensor reading? Am I reading a misprint or is my MAP sensor bad?
BoostedSUV
Re: MAP Sensor Reading Good or Bad?
That is understood. I have pressurized my intake and found no major leaks. I have also gone hose by hose with a vaccum pump and found no leaks.
No major leaks? Or no leaks at all? There's a major difference there... When you pressurize the system there shouldn't be any leaks at all. What kind of vacuum do you have at idle?
As far as the map sensor I couldn't tell you what your readings mean, I've never tested one.
SacDoug
If you have ever pressurized an intake, you will know that it is nearly impossible to have an automotive intake that does not leak under pressure.
I send 20 psi of air into the intake then sprayed soapy water around all vacuum lines, throttle body and intake manifold. I have T-bolt clamps and the hose from the intercooler to throttle body still has very small leaks. Everything that bolts ot the intake has a small leak. There is a small leak around the EGR valvue, around the throttle body and various other parts. The thing is that these leaks are very small. They are just enough to make a few bubbles.
Try it yourself if you have an air compressor. You will see what I mean. There is no such thing as an air tight intake on any production car that I have seen.
black cat
hey i have some rough # for ur map. 1 bar @ 20 in vac approx .2 to .5volts and at 0 in vac or wot is 5 volts. 2 bar @ 20in vac is approx.4 to .6 volts and at 0 in vac is approx 2.3 volts and at 15 psi is 5 volts. 3 bar @ 20 in vac is approx the same as 2 bar and at 0 vac about 1.6 volts and at 28 psi about 5 volts .these # will change depending on elevation and type of map.these are ball park hope the help
SacDoug
That is perfect! So my numbers are within range and I now know my MAP sensor is good.
