Max HP with stock 2 bolt block
thunderace31
Just wanting to get some info on where the cut off is for HP on a Stock block with Forged pistons and Good Forged Eagle Rods and a Nitrated Stock crank.
With just the 2 bolt mains and ARP Bolts whats the max before these start coming apart??
Id like to get to the 500-570 or there abouts HP rang to go high 11's
Thanks in advance for the info.
cloneman315
Re: Max HP with stock 2 bolt block
should be fine,just dont detonate it,thats the key!! And put a wbo2 on it!!!
thunderace31
Got an AEM wide band for it :)
Anyone use the denzo o2s to replace the factory one?? They do a lot better with Leaded race fuels and Alky
turbodig
Stock blocks have made well into the 600 HP range, into the 700s in a few cases.
( I wouldn't plan on a long-term relationship with a 700 HP stock block, though)
Stock blocks have failed at 280 HP.
If you don't let it ping, it'll be fine. If it pings, it'll die quickly.
thunderace31
I agree on the knock issue I had a 130,000 mile bone stock block GN and ran 30psi with no knock and I never blew it up :)
Just wish there was a real good way to manitor knock on these trucks :( Scanmasters are the best for this in GN its right there in your face!
