max recomended timing on C16
SYCLONE#1531
'MOFOFAST
Im getting my truck ready for the Nov 20th MCE (MUSCLE CAR EVOLUTION TRACKDAY) located at Reynolds Drag Way, GA. My question is how much timing is common to be ran with C16. My RPM multi chip ranges from 26 to 30 degrees of timing. I have found the truck spools and runs the best on 30 degrees. 24/25 psi:eek:. I wonder if I could squueze another 2/3 psi out of it??? Has anyone ran this much timing on a stock unopened long block? The truck really seems to like it!! For a some what stocker, it will sure now pen you to the seat from both a roll and dig!! Im hoping to get mid 11s out of it. Before, It ran 7.90s 1/8th aprox 12.5s with the stock turbo and 2 bar Hood tune.
Specs:
RPM MULTICHIP tuned for C16
PTB 61mm .85 exh
3 down pipe, 38mm external wastegate/ 3 in all the way back
fmic
60lb injectors
2800 9.5 stall
RPM fans
RPM ac delete
It's just a six
Super Member
Re: max recomended timing on C16
Did you run it on a dyno to see if it actually makes more power @ 30 degrees timing?
Most times w/my butt dyno, my Sy will feel fast out of the hole w/more timing , but lose a bit of top end power.
More than likely,ruduce the timing & add a couple psi.
I would put it on a dyno or test it first on a track before your actual race. Or G-tech it or ?
What your knock retard.
Good luck, hope it does good!
turboj91
That's what timing retards are for.
To the OP/subject at hand. Deep read the plugs. They will tell you exactly what you need to know.
turbodig
:stupid::git::tup:
The plugs will tell you everything you need to know.
x3. At those timing and boost levels, if you haven't looked at the plugs really deeply (ie, cut 'em up) at least once, you're looking at dead motor parts somewhere near in your future.
If you plan on regular racing, I'd highly suggest either leaving the fenderwells out (and supporting what needs to be supported) or getting a set of junkyard S10 fenderwells and cutting a big plug access notch in them.
Frequent plug reads are the key to survival in a racing environment.
30 degrees sounds like a lot to me, but if the motor wants it, it wants it. Personally I haven't seen much gain past 23-34 at WOT, but different motors do different things.
SYCLONE#1531
'MOFOFAST
Im gonna data log it this weekend with my buddys datamaster to see if im getting any knock retard. This will be the first time for me/truck with datamaster. I pulled # 1 and 2 Plugs and they had a nice chocalate brown color.. no signs of detonation. (BLACK PEPPERY SPECS)? I didnt pull the rest being such a pain it is. Wideband shows im in 11.5 ish range WOT. Here are the chip settings provided my Mike (RPM)
It's just a six
Super Member
It seems, most guys on the Turbo Buick forum run higher timing in 1st & 2nd gear,but in 3rd,they reduce there timing a bit,I know different engine but,not sure if our engines need a little less timing when pulling the taller gears also?
MIXEDBREED
To read plugs correctly you need to use a spark plug reader tool 10x mag and should cut off the threads to view your fuel ring. Just using your eyes is not going to help much.
It's just a six
Super Member
Updates?:tup:
