Ian Turgeon
Cascading Inspiration
I've read there are 2 method comonly used in turob building.
The older stuff was built with seperatly balanced parts, and simply bolted together, while the newer stuff (and I believe a mis-conception by all that ALL turbos are done this way) balanced as an assembly.
Looking at my mitsu, It appears the balancing work is done individually per piece. the compresser wheel has some semi-circles missing from the back-plate of the exduser side. The nose of the wheel is missing some material. However, the nut holding the turbine/comp wheel together is entact ( from my understanding parts balanced as an assembly usually show adjustmets here).
So my theory is, if they are balanced as individual parts, I should be able to replace just a compressor wheel, without having to get the assembly ballanced.
Can any one back that up or throw it in the dirt?
also... where could one pick up a 20g wheel?
