Moates Part Numbers and file links
WyoSyclone
A lot of guys have asked me to make a list of parts I used to put together my 'remote connect' package for tuning... These are all the parts you'll need to connect to the ECM, bring a cable out from behind the dash so you don't have the ECM hanging, and the parts associated with holding the chip, etc.
Also the link for tuning/logging software, some pics, and a thread here on the forums for wideband install.
Hope this helps :D
My Moates list for tuning and logging hardware.
First item.... a laptop... then....
Model: ALDU1_CABL1
www.moates.net/aldu1-and-cabl1-xtremealdl-and-newcabl1-combo-p-127.html?cPath=64
Model: BURN2
www.moates.net/burn2-chip-programmer-p-197.html?cPath=64
Model: FLASHBURNPRO
www.moates.net/flash-burn-program-for-burn1-p-67.html?cPath=64
Model: GP1
www.moates.net/gp1-package-gm-adapter-with-2-chips-p-41.html?cPath=64
Model: EMUC2818
www.moates.net/emuc2818-emulation-cable-28pin-18inch-p-64.html?cPath=32
Model: FERRITE45MM
www.moates.net/ferrite-bead-for-45mm-usb-cable-p-203.html?cPath=32
Model: CHIPEXT
www.moates.net/chip-extender-10-p-172.html?cPath=26
- You'll need a small plastic box to mount the CHIPEXT into
- You'll want to get (4) four of the 1/4" thick felt (3/4" diameter) pads to space the cover of the ECM away from the case.
- You'll want about 3" of 1/4" diameter convuleted tubing to place over the edge of the ECM case so you don't rub the insulation off of the ribbon cable.
- some tape to tape the ribbon cable to the ECM
For logging:
1. Datamaster
- http://www.ttspowersystems.com/DataMaster_downloads2.html download the DM35xT for Syclone, Typhoon .... OR......
2. TunerPro RT (now version 5)
- http://www.tunerpro.net/downloadApp.htm
Support files for TunerPro5 here at Code59
- http://www.code59.org/index.php?option=com_docman&task=cat_view&gid=41&Itemid=35
ECM Access pics...
http://s137.photobucket.com/albums/q230/wyosyclone/ECM Access/
Some ECM pics (has some Moates parts pics as well)
http://s137.photobucket.com/albums/q230/wyosyclone/ECM MEMCAL Moates/
Pics of how the Moates pieces can be put together to form the 'extender', which makes chip swapping (or emulation plug in) very easy
http://s137.photobucket.com/albums/q230/wyosyclone/Moates Extender/
O2 removal and wideband sensor install:
http://s137.photobucket.com/albums/q230/wyosyclone/O2 removal and WBO2 In/
And... the PLX wideband install thread....
http://www.syty.net/forums/showthread.php?t=48363&highlight=plx
keywords: tuning, code59, moates part numbers, moates, wideband install, tuning help, PLX install
Static
Re: Moates Part Numbers and file links
This will be very helpful to have all the info in one thread. I know when I did mine I had to piece it together thru searches.
johnboy89
What did you use for the small box w/ cover??? Would be nice to be able to buy one???
WyoSyclone
Sorry, I used one of the SoundGate interface boxes from when I had the company... I think Radio Shack still sells some small 'project' cases. If not you may try eBay.
Chest Rockwell
Nice work on this thread, Rob. How's the new job/digs? Any snow in your new neighborhood yet?
sytyguy
Moderated User
When I saw the title, it reminded of the old days when I used to remote login (LogMeIn, TeamViewer, RDP, etc...) to customer's PCs and tune their trucks.
WyoSyclone
Hi Steve, thanks for the thoughts.. job is going pretty good - just the normal 'new guy getting used to new company type stuff'. No snow down here, but plenty back in Wyoming!
I love TeamViewer, Michael. I use it to log in to the computers at home and keep track of the ZDDP business, etc. I never thought about using TeamViewer for tuning... you're light years ahead of the me ;)
turbodig
x2.. I use teamviewer a lot as well, and have done some tuning that way.
With smartphones/usb 3g/4g, you can even tune while the person is driving. It's kinda freaky.
We actually have a corporate license for teamviewer at work, for supporting stuff on people's personal devices. (Laptops, Macs, etc)
Quickstop [UK]
Combating adversyty.
I connected to Team Viewer with my 3G and qbnkiller tuned my truck while I drove :D
