Modded ECM...how important is the jumper?
TYTILIDIE
METH HEAD
When you mod your ECM for lowZ injectors and you put the jumper between the cxx and cxx (you know what I mean I hope) how important is that part of the mod?
turbodig
Re: Modded ECM...how important is the jumper?
Unless you re-wire the ECM, it isn't running peak and hold.
There are quite a few guys saturating the heck out of low-z injectors, but that isn't how the injectors are to be run, and isn't going to work the way it should.
Unless you have need to run larger than 80# injectors, I wouldn't run low-z, personally.
TYTILIDIE
METH HEAD
Little late for that. At the time when I bought those everyone said 75's were the only way top go. So here I am.
So are you saying tht if I take that jumper out I will have no problems? I don't even understand why you are supposed to do it. Where can I find instrucioins on re-wiring the ECM?
turbodig
There's a code 59 thread on the P&H wiring.
As it's wired for stock, the P&H circuitry is bypassed in the ECM. When you pull the jumpers (and ground accordingly), the P&H chip can sense the current going through the injector, and switch from "Peak" to "Hold".
The size of the sense resistors is critical to it working properly, as well. The size of the sense resistors will change with the number of injectors you're running per driver.
It's a good idea to use both drivers on the ECM as well, but that means you have to split the injector harness, and run another wire. Not too terribly tough.
