more power part throttle?
Osmosis
I have a strange issue with my typhoon. Ever since I purchased it, the car runs strong, but If I'm in the throttle, I can back my foot out of the pedal aprox 1/8 of an inch and I pick up significant power. I"m guessing I'm getting more timing when I pull my foot out that tiny bit. My aldl runs show no knock on my current tune. I'm runing a tuned ultimate bin Version11 18psi street/strip version.
Any ideas?
turbodig
Re: more power part throttle?
Any ideas?
You answered your own question. The chip isn't tuned for optimum power at WOT.
TYTILIDIE
METH HEAD
Any ideas?
Many many many people have had this problem before. KR is obviously the first culprit. If I were you, I would check what your AFR is at that TPS. In other wards, see if you are running rich or lean. Timing definitely can be a factor in this as well. What is your timing when you are 100%?
Osmosis
15.82 15.47 15.47 15.47 13.71 7.38 5.98
15.82 15.12 15.12 15.12 13.36 7.38 5.98
14.41 14.06 13.71 12.30 11.60 7.38 9.84
14.41 14.06 13.36 13.36 12.66 7.38 9.84
12.66 12.30 11.25 11.25 10.55 7.38 5.98
12.30 12.30 11.25 11.25 10.55 7.38 5.98
11.25 11.25 11.25 11.25 10.55 7.38 5.98
11.25 11.25 11.25 11.25 10.55 7.03 5.98
This is the 190map up to 288 map in tuner pro.
I don't have an AFR gauge or a EGT gauge:( YET.....
I did upgrade my turbo from stock to Mike Lee's stage 3 60-1 ball-bearing turbo. Both stock and new turbo have the same symptoms at part throttle vs WOT. I have a chip tuned with zero KR for both turbos. I am having some lag with the larger turbo and I plan to remedy that with a 2800 stall.
Thanks for the ideas!:tup:
TYTILIDIE
METH HEAD
I dont know, looks to me like you need way more timing. My personal opinion would be to get a tune done.
Osmosis
I'm wondering if it's more fuel related because when I pull my foot out of the throttle just a little, aprox 1/4- 1/8 of an inch, my typhoon really pulls hard! This could be timing OR fuel. consequenlty, I don't have a Wide band yet.
also, When you hook up a wide band, how can you see how boost, rpm, and AFR relate to each other? Will tuner pro give me a printable xdf file for these values? I have done a lot of data loging with tuner pro via aldl port, no real time emulation yet.
Thank you again!;)
Osmosis
I just spoke with a dyno shop for awd cars. He thinks my problem is more of a torque converter issue becasue of hte power @ part throttle, but is gone @ wot.:(
Osmosis
I am spraying akly. My alky turns on @ 12 psi and I"m running a 7 gal/min nozzle. I run pure alky. I have the stock intercooler with the pump running all of the time.
One thing I have noticed is that I have had this problem when I started using the ultimate chip. Looking @ the timing tables, there is a ton of timing pulled out of timing @ wot. I"m sure this is for safety issues and detonation. But when I back off on the pedal, I get power.
Things is could be;
Intercooler not cold enough.
I plan to remedy this with a sure flow pump and aux. resivor for more coolant.
Timing issue
Chip burn and Wide band O2 kit...soon I hope!
Torque converter
New converter coming soon I hope
TYTILIDIE
METH HEAD
I dont see a TC causing this problem. I was going to say check to make sure your IC is not leaking inside. This happened to me and a friend of mine. Not sure why it bogged the truck down under WOT since the shurflo pumps the same all the time but that is what happened. Sounds like your tune for sure. If it didn't do it before the Ultimate and now it does it, then that has to be your problem.
NecroWolf
lost marbles member
with the alky you can run more timing and since you're saying there more timing at part throttle than wot i'd say that could be what you're feeling. or your chip isn't setup for the alky and when it sprays its bogging the motor.
Osmosis
I did some testing today. I increased my timing and I did get a better responce. Then I pulled some timing and got even better resonce...but all positive results was at teh seat of my pants and WOT still sucked compared to pulling back 1/8 pedal distance from wot.
I also increased the fuel cells with good repsonce. I increased my fuel pressure to 58 and got OK results.
The part that sucks, no real difinitive change and my wot still is suffering. I really need a wide band O2 or a dyno:squint:
ZavzTy547
Senior Member
Technically, the ultimate bins aren't set up to use alky, since the tables are setup to run rich as it is..
You'll have to reburn the ultimate or run code59 to take out the fuel and add timing to compensate for alky.
Osmosis
I started with the ultimate chip version 11 and I have been tuning it since I've put it in. Adding fuel, pulling timing where it knocks, adding timing ect..
I do have a chip I"m runing code 59 on.
I really need a wide band, but I can't afford it right now, well, I can easily afford it, but my wife would loose her mind! I just dropped 1300 on a turbo, few hundred here, there..... I"m sure all you married guys know exaclty what I mean!:lol: However, if it were not for my wife, I'd have a bitchen shop with 10 of my favorite cars....and a 2x wide instead of an awesome house. balance is the key..I guess...man, I really want a wide band kit:(
ZavzTy547
Senior Member
Peeps who are married like myself understand your pain. It's very hard to tune without a wideband. You can always sell parts from your upgrades to help finance your wideband like your stock turbo for example...
Osmosis
I want to keep my stock parts as these trucks are becoming more rare each year. I have always kept my stock parts on my hot rods. It's easy to sell the hi-performance stuff:tup:
TYTILIDIE
METH HEAD
Never have I let marriage get in the way of me and the Ty, ask anyone who knows me;) IMO, opinion, anyone who says its me or the ....... isn't worth it:2cents:
sharkbait
come on thats a little harsh. its part of being a big boy. give and take right? you cant upgrade your turbo when the wife needs to buy dishes to serve your food on.:rotf:
