Raist103
ok i have desided my antifreeze is leaking from the front of the block, i do not want to remove anything that i do not have to but i can not see were it is leaking from. it must be 1 of 2 things. 1. freeze plug or 2. cracked block. now i have the fan and shroud off and do not want to pull the ac comp off, since that is a pain to get off. i do not want to crack any of the cast backets since they are all new. whta can i get away with leaving on and still get to the freeze plugs of the front of the block? anyone have a pic of the front of a bare block so i can see where they all are?. or do i have a way to them if the brackets are still on if i remove the grill and rad? since that is the quickest.
