MSD 2step launching
Turbo6
10.20@131.8
I thought I would experiment with the MSD so I could get more consistant launches and not have to watch the boost gauge while staged. I installed an MSD 6AL with the 2step module and timing retard box. I put a button on the steering wheel so I could turn off the low RPM limiter and timing retard (if needed) at the launch. My tq converter stall is about 3400-3500 so I put in a 3200 module to start with. It made 12psi at 3200. 16psi with 10 deg retard and 22 psi (the setting on the boost controller) with 20 deg retard and no the truck did not creep foreward because the rev limiter was helping load the motor alot instead of depending on the tq converter to do it all. Stuck in the 3000 rpm module and got 14psi with 10deg retard. I really dont plan on ever retarding the truck 20 deg retarded at the line but it was an experiment. 10deg retard is very safe and still get 16psi at 3200. The benefits of this should be that it that its easier on the trans and you can launch the same every time. If it spins you can just lower the retard or turn it off. If it still spins you can lower the RPM of the 2step. The only launch I have tried was on the street at 3200 rpm and 10deg retard and the truck was spinning and got sideways. It may hold a launch like that at a good track. I think Waller uses a setup similar to this.
GEN3Typhoon
I did not know that you had a Sy.... We met at Rockingham one time.. that was when I had my Red Corvette with the Nitrous on it.
Interesting.... what happened to the Cobra?
ed hess
race or get outta the way
when using the 2step, how fast does the motor recover?
what i am getting at here is once you let go of the button, is the return to normal engine poser instant? i.e.
just asking so i know what to expect once i startusing the 2step in the dfi7?
ed
Turbo6
10.20@131.8
I sold the cobra in Feb. There were very few days I could drive it because of have no top and with all the rain we have had I am glad I sold it. 600hp and 2200 pounds was damn fun though. What is Andy doing these days? I have not talked to him lately.
Turbo6
10.20@131.8
ed
It hits instantly. You will love it. I hope to go to the track Thurs. to try it if it doesnt rain AGAIN! I can even get 8 psi in neutral! (not that it matters) I would love to hook it to some line locks but I'm too lazy. :(
Boostn
91 Syclone on a diet
hmmm, so if you had that rev limiter with timing retard and line lock, would you be rigging them together in one button to make it easier to disengage them?
ed hess
that is exaclty how mine will be....except the same button also sets the stage mode on the innovative boost controller!
ed
Turbo6
10.20@131.8
YEP! :eek:
Boostn
boy, you guys should let me know how that goes after you got it all done. I'd be interested in trying it myself with my Syclone. Thats pretty cool idea and hopefully it works. ::brews::
ed hess
just need the trany done, and then harry can tune the dfi7 and im there!
ed
pretty soon im gonna start dreaming about tranny in my sleep. :(
