My fram filter
BeastMaster02
Re: My fram filter
The link tunerpike put up has a wealth of empirical research and findings in it. I've seen this before, and the author has updated some of his findings from time to time. I read some of it the other night. Without going back and reading again, here's my recollections:
The Mobil-1 and K&N are the same filter, other than the wrench hex on the K&N. Made by Champion labs, and both very good. These have a silicone rubber drainback valve, which is better in cold climates to prevent dirty oil from getting into the clean oil side.
The Wix is a very good filter. Has a nitril drain back valve. Not quite as good as the silicone. Has a metal-seat bypass valve which may leak slightly, but not a big deal.
He also likes the Purolater Pure One. this filter is also sold under other brand names. Has a silicone drainback valve.
I don't recall anything about the Royal Purple filter.
Having said all that, read this. This is the authors' personal feelings and recommendations on filters.
Thank you Sir.
Logan
Re: My fram filter
I sold car parts for a couple of years in college and after a little research and "educated" customer discussing their opinions on filters I use Wix on all of my applications. I have never had any quality issues with them and after seeing how many fleet companies (we had a lot of them where I was) would live and die by Wix I figured all of these people couldn't be wrong.
kmack
Re: My fram filter
Guess what guys
Fram makes many of the Alternative filters you are talking about.
They build filters under all kinds of names.
They are a huge player in automotive commercial and industrial applications.
Filter technology is a bunch of smoke and mirrors.
Generally (but not always) price is indicitive of quality.:2cents:
Re: My fram filter
Guess what guys
Actually, they don't. Honeywell makes Fram filters and only a few others of the most popular and memorable filters. Pennzoil and Quaker State are the only recognizable names I see besides Fram, that are made by Honeywell. Again, Fram doesn't make filters and they definitely aren't the same as what's inside of what most people are talking about in this thread.
http://minimopar.knizefamily.net/oilfilters/reference.html
One thing should be pretty clear if you have made it through this entire article. While there are dozens of oil filter brands out there, there are only a few actual manufacturers. Most filters you see on the shelf are sold by companies that don't actually make oil filters. The exceptions are Baldwin/Hastings, Champ, Donaldson, Purolator, and Dana/WIX. Those are actual manufacturers and you can be fairly certain of what is inside the can. Although Fram hasn't made filters in decades, it seems that the brand is tied closely enough to Honeywell that you can be pretty sure about what is in the orange can (for better or for worse). Most other brands contract one of these companies to make filters for them. They seem to change from time to time, so one has to be vigilant when purchasing one. See the overview page for a quick manufacturer reference including images of their backplates.
If you want to hear my opinion take a look at the Oil Filters Revealed: Opinions and Recommendations page. Which filter is the best? There is no easy answer to that one. It depends on what kind of oil you use and how much you are willing to spend.
BMFB
Not to scale
Re: My fram filter
Guess what guys
I tore apart a fram and a puriloator, they are super different.
Strykerblythe
Bowfishing King
Re: My fram filter
I had a buddy of mine who wouldn't listen to me about not using a fram filter on the motor he was building for his truck shortly after he finished it lost oil pressure and blew up the motor... So I decided toto show him why i ppulled the filter off the motor and the filter had imploded in on itself and block up the oil lines
warmpancakes
Re: My fram filter
brian I have a place I order wix from cheap let me know what you need they are usually 3-6 bucks each for normal carns (diesels are more)
Re: My fram filter
This is one of the main reasons I want a good filter on my truck. It will hit 60# of oil pressure on cold start-up, as I'm sure many of you do. I do not want a filter known to implode on my truck or anything else I own either.
VERY wordy but interesting article on oil which kinda fits here. (This guy needs an editor really bad.:rotf:)
http://www.bobistheoilguy.com/motor-oil-101/
