BeastMaster02
Re: My fram filter
Thank you Sir.
The link tunerpike put up has a wealth of empirical research and findings in it. I've seen this before, and the author has updated some of his findings from time to time. I read some of it the other night. Without going back and reading again, here's my recollections:
The Mobil-1 and K&N are the same filter, other than the wrench hex on the K&N. Made by Champion labs, and both very good. These have a silicone rubber drainback valve, which is better in cold climates to prevent dirty oil from getting into the clean oil side.
The Wix is a very good filter. Has a nitril drain back valve. Not quite as good as the silicone. Has a metal-seat bypass valve which may leak slightly, but not a big deal.
He also likes the Purolater Pure One. this filter is also sold under other brand names. Has a silicone drainback valve.
I don't recall anything about the Royal Purple filter.
Having said all that, read this. This is the authors' personal feelings and recommendations on filters.
Thank you Sir.
