Rawpwr7 said:
i made the cable also..when i connect it DM TT says that my pcm is not the correct version???? but the cable communicates with the PC?????
So you can open up through Hyperterminal and you get echo of what you type?? I'm not sure I've seen that error message before, but I would imagine it is easily corrected. The circuit is pretty simple.
Post back if Hyperterminal works and we'll go from there.
If you aren't familiar with what I'm talking about. Go to Hyperterminal on your computer (it's under the Accessories > Communications in the start menu). Open a new connection (named whatever you want) and set the communication through COM1. Set the bitrate to 9600 or so, and start the connection. If your MAX232 chip is powered up correctly, it will echo anything you type in the window. If you get nothing or gibberish shows up (not what you typed), then there is a problem.
I'm sure it's fixable.
