I had a thought today (well actually I considered this in the past, but even more so in recent days) about how to setup the Ultimate programs for the 50# setups.
Problems:
-I don't have reliable boost control setup on the 50#/PTE setups yet, due to time constraints. Physically, it can be done, I have proven it, the time just needs to be spent tuning. Another problem this brings up is if different boost calibrations are needed for the different range of turbos/mods. One boost calibration might not work for one person, but is great for another.
-The 50# calibrations need to have some flexibility (fueling-wise) for different modifications/levels.
The possible scenario to solve these issues, which I wanted some feedback on:
Leave boost control out of the Ultimate's programs, instead offer varying fueling & timing levels only, forcing users to purchase *some* sort of boost control. Yes, this gets away from the bang for the buck of the Ultimate, but it also allows for some extra tuning which IMO is necessary at this level, as buildups vary SO much. Just adding headers to a build can necessitate a change in fueling, let alone the different turbos out there, if people are running alcohol, etc. Jeff Scott has already done some wideband 02 datalogging which confirms what we already knew. He's running programs I dialed in on a truck with a TE45 turbo, headers, air-air and some port matching. I had the AFR at about 12:1 at 15psi. He has a truck with a TE44 and minor mods. His AFR was in the 10:1 range. He would benefit greatly from less fuel at WOT.
So the Ultimate program listing (16 program slots) might appear like this:
1- Security, no start
2- Valet, reduced performance & emissions (closed loop program)
Street programs ~14 deg of timing at WOT
3- street timing, fueling level 1 at WOT (leanest)
4- street timing, fueling level 2
5- street timing, fueling level 3
6- street timing, fueling level 4
7- street timing, fueling level 5
8- street timing, fueling level 6
9- street timing, fueling level 7 at WOT (richest)
Strip programs, ~17 deg of timing at WOT
10- strip timing, fueling level 1 at WOT (leanest)
11- strip timing, fueling level 2
12- strip timing, fueling level 3
13- strip timing, fueling level 4
14- strip timing, fueling level 5
15- strip timing, fueling level 6
16- strip timing, fueling level 7 at WOT (richest)
This would allow for *lots* of flexibility and tuning. Instead of manipulating fuel pressure left and right, you could leave fuel pressure alone (for the most part) and toggle between programs to alter timing & fuel. From what it seems, most people were having best performance with the T2 timing in trucks, so T3 would be left out. With the larger turbos, you are better off running more boost when octane allows for it anyways. If you do require more timing, you could always add it in mechanically.
Boost control solutions:
By having to purchase/arrange for other boost control options, you allow for even *more* tuning, which sounds like complicating issues, but it's really offering more tuning options, which is a good thing. The Buick guys love the Boost Commander from Ramchargers http://www.gnttype.org/vendors/inventimages/BstCart1.jpg www.ramchargers.com and it is fairly inexpensive. Other people are trying out the Jap car boost controllers (Blitz etc).
Having a setup with the 50# Ultimate and such a boost controller offers you to really dial in a setup - from your driver's seat you will be able to change your fueling, your timing, and your boost control, all independent of each other. Go to the track, grab your laptop, fill the truck with some race fuel, and go. For those exploring the alcohol injection route, this allows you to lean out your fueling and increase the amount of alcohol injected. Also allows your truck's performance to grow. You could buy a PTE51, get this chip, then down the road upgrade your intercooler, or headers, or both, and still have the adjustability to take advantage of those mods.
I'm also of the mind that a good bleeder should work ok with the PTE setup. Also, I'd probably set in a set wastegate duty cycle in the chips, so the programs would actually have boost control, just that they all might be 18-20psi programs. My reasoning in this: for those on a serious budget, you could run without a boost controller and have 15psi base boost on the PTE wastegate setup (as its a high boost actuator) then plug in your solenoid when you want to throw some high octane gas in for the track, to give you a bit higher boost. So effectively, you have boost control with the chip, just that your options are limited.
Let me know what you guys think...
Problems:
