Need feedback for 50# Ultimate chip
smeagol
I go more for simple functionality. It isn't outdated, it's basic.
I like to look to the Turbobuick guys to see what works for them, their vehicles are much more similar to a syty than any high revving manual Jap turbo car. Seems like every Buick guy uses one of several options - 1 - chip control of integral - 2 - external controlled by regulator - 3 - Boost Commander control of integral - 4 - bleeder control of integral wastegate. I haven't read up on any other controllers being used; the Innovative one that Mike sells is the next one I'd recommend if you want to spend some cash.
Why spend $400-600 if $160 or $10 worth of boost controller does all you need? If the expensive ones are guaranteed to control boost 100 times better...than i could see the need, but no one has proven that the PTE setup won't work with simple boost controllers like I have mentioned.
The Boost Commander is nice... basically it offers you direct open loop control of the solenoid. The solenoid duty cycle is directly controlled by the knob. The TPS trigger allows for ramping of the duty cycle based on throttle position - so the solenoid won't pulse until XX % throttle, based on what you set it at. The extra trigger input can be used in many different ways - you can set it so at TC lockup the duty cycle drops a bit, helping control boost spike - you can set it so if your low alky light comes on, duty cycle drops huge, so your 22psi setting for boost with alky on drops to 16psi when low alky light comes on. You can set 2 boost levels, one for track, one for street, flip a switch and be in race mode. I'm considering looking into the possibility of using the IC pump turnon output for something to trigger the boost controller - aka if > xx degree of knock, the wire goes 12v hot, and lowers boost by whatever amount you set in the controller..
Granted there are some mega buck boost controllers with some added features, but you pay big bucks for something doing the job that a less expensive controller may do fine. Buick guys are using $10 bleeders and are happy with those.
If we determine the PTE stuff is difficult to control... I may have to recommend some other form of control...but I don't see that being the case.
smeagol
No worries. We'll have some feedback on some setups soon I'm sure.
We may try a Boost Commander on our test Sy here.
Sy#26
>Brian- any chance for a variable fuel curve? Like actually >leaning out fuel as alky/water starts?I currently have to either >run rich under boost and limit alky or run lean up to 12psi and >then push lots of alc.
>Jeremy
Initially, I installed the Aquamist 2c system which uses their "High Speed Valve" - this pulses in time w/ the injectors, so's the ratio of injected stuff to fuel is always the same. I'm not familiar w/ the other alky kits, but the HS valve from the AQ system might be the fix for your prob. Replaced the AQ pump w/ a higher capacity (& cheaper) ShurFlo unit - works very well. Duty cycle is around 30% using 2 x 0.6mm jets @ 225 psi. Adjustment is either pump pressure - up to 225psi, or jet size. Lots to play with.
As a side note, when I put my new engine together, I inadvertantly installed the cam 4° advanced (favors lower rpm range) - had to *drastically* reduce fueling above 4000 rpms. Tuning to the same 12.5 AFR, VEs are down by almost 50% up there now. Next weekend, gonna put it back in, straight up this time; I'm surprised @ how much less air actually gets into the chamber now..
Boost control wise, some comments. I have both an HKS and an enlarged WG hole & flapper (Chan) in my 14cm. They both work equally well, so the HKS is coming off. Did back to back runs using both, no difference. Using a pressure regulator setup on the HKS, high pressure actuator (19-30#) in the enlarged flapper integral WG. Just adjust the rod length for whatever boost you want; not 'in the cab' adjustable, but simple. For my 2 cents, I favor non ECM boost control. What I'd *really* like to see is a linear actuator, electric maybe, to actually control the WG - open it far & fast, close it the same.
Question for Brian - the only mod I don't have @ this point is headers. You mentioned a fueling change needed when they were added - how much?
FWIW, YMMV, etc -
Barry
smeagol
I don't know Barry. I haven't done before and after testing. I am convinced that the headers do provide gains, and if that is true, it will require some fine tuning from running with the stockers. Josh Benedict might comment here with his results with the headers.
Don't get me wrong, i'm all for the bang for the buck and pushing for the stock stuff, I just have a philosophy for Syty's to get into the 11s on stock motor stuff, and headers play a part IMO.
xcaliber
Well my truck has been down for a while, one reason I have not been hyped about doing my build is the tunning issues, I chavent been able to decide between saving the bucks for a fast (speedpro setup) or trying to learn chip burning ( a lot more work but cheaper) and as with most everybody money is a major issue.
my point is this, I am smart enough to figure out a way to control boost,
but fuel/timing is above my head
having differnet fuel curves to chose from sounds perfect
this new chip sounds like the best option for the masses! :lol:
Jamie Sanders
sy 0252
Heber springs, AR
10secTy
Sy-Ty builder and Tuner
I have a Boost Commander for my Typhoon if it ever gets finished. You will have to get a GN boost solinoid and do the vacuum hoses for the wastgate like a GN.
All good ideas on the 50's, hmmmm maybe at the end of the summer you will be able to offer a 75 program as well :wink:
Nolan
smeagol
Talked to Bob Bailey about it. He believed it would work ok with the Syty solenoid.
I'll be testing it next week ;)
Nolan, do you have a copy of the instructions online at all? I'd like to go over them a bit.
75s should be fun
10secTy
I had read and talked to some people about it. The GN system uses a soiniod that is t'ed into the line so the off position on it is closed so the wastgate gets the full boost signal.
On SyTy the off position is open and wastegate gets full boost signal.
I will pull out the directions for it tommarow and get TurboTony to scan them and send them to you.
Also instead of using the TPS voltage as the trigger I am going to use the MAP voltage. This way it will trigger at a certain boost level and not a certain
TPS level. Any way we can go over it more tomarrow. I need some sleepy.
Nolan
smeagol
I hear ya Nolan. I emailed Bob Bailey the exact question - basically that the duty cycle was reversed on the Buicks. He replied that 100% DC on a Buick was full boost. It didn't make sense but I believed him cuz he is one of the Buick chip gurus. Yesterday I even tracked down some Buicks so I could stare at their wastegate solenoid setup.
Anyways, if it is just altering duty cycle, is there any reason it still can't be used on a Syty solenoid? min would be max on the adjustment knob, up would be down as far as steps for any extra inputs... other than that, can't see any reason why it wouldn't work.
Also, he mentioned about the scaling of the solenoid, said he could change the Boost Commander if it needed to fit the scaling of the syty solenoid better. Heck if it comes down to it, I know where I can get a Buick solenoid ;)
The MAP idea is a good one, it's how the Syty chip does it, must be OK.
BigAl...
Hey BG, (not sure if this makes any sense, since I just pulled it out of my ass :wink: ) since the buick solenoid is reverse to our's, could it be used to control an external wg? I thought I remembered you metioning we couldn't use our solenoid because it worked reverse.
BigAl...
smeagol
You could setup either to control an external, it's all in the vacuum line routing.
Where it really matters is the calibration of the chip, and/or the boost controller.
I setup a chip to control an external before. It just takes chip know how. The fact that almost every person out there uses a different external gate makes it kinda impossible to make a one fits all calibration for externals in chip programs, plus the fact that there is only 24 hours in a day.
xcaliber
:lol: This chip sounds great, and I have a question, I am starting a rebuild, 96 vortec heads, bigger turbo 54 or 63, headers, 50lb inj. and air to air, (this sounds like a popular setup from what I have read here.)
so my question is, is this the chip for this setup? and this is a long shot I know but any idea as to how much better speedpro would be, I know,, hard to answer that due to tunning issues, I am just trying to talk myself out of spending that 2,200 for speedpro. any help here would be greatly appreciated
P.S. to the individual that sent me the private message, I have that item you need, give me an address and it's yours, (you know who you are)
jamie Sanders
sy 0252
Heber Springs, AR
smeagol
This chip we are discussing here is for the stock motor setups runing big bolt ons, so No to your answer, but I am working on the heads/cam buildup 50# calibrations as well.
Anyways on your buildup..., do yourself a favor and get a cam. Those heads will like it.
I recommend the Comp Cams 09-412-8
Chip vs FAST
If you are after all out speed, the FAST will probably be better, as long as you have a clue as to tuning or will have it tuned professionally. Why? The calibration will be completely custom for YOUR truck. We have some chip programs that are coming along for your type of buildup (which is one reason I recommended that cam), and they should be running very well within a few months. The chip will offer good bang for the buck, with good drivability. If you are afraid of FAST, on a budget etc, it's the way to go IMO. John Waller and others have tested (and will be doing more) with this combo. I know John will be doing some serious racing, and has done wideband 02 tuning with his, so the calibration will really come along. Also, in the far off future, I should have a Syclone I'm very familiar with running a similar build for me to tune locally.
xcaliber
Thanks for the reply!
and yes, I am going with the cam you mentioned, but forgot to put in the prior message, I got the part # from one of your way earlier post (it seems several use it and are happy)
this sounds good, by the time I get everything done, machine work, parts ordered, the chip should be comming around. and I can use the extra money saved on FAST system for other things, I also forgot to mention adding a fuel pump, I have it on the shelf with the other parts. new steering wheel, "do you want my old one" and a BOV from the group purchase just for the sound!
I cant wait to get thing done, it will be a totaly new setup, with new mods nobody has done, with some new ideas, gages mounted in dash, that will look like a smaller version of our instament cluster, turbo on the "wrong side" for cleaner, shorter piping, big powerstroke intercooler, mounted in radiator spot with radiator behind it, I have checked clearences on this one it will fit, yea me!!
Jamie Sanders
Sy 0252
Heber Springs AR
smeagol
Jimmy - yer running an ATR cam, right? You have been using the heads/cam program I believe. You can give the stock motor cal a try if ya like, but I don't have the update going out yet.
