Need help
typhoon92
i have installed my ultimate chip 7 ,fpr set at 50 and 3bar map sensor. the problem i'm having is that when i start to build boost it starts to knock.things i have already checked timing with tan wire disconnected and the timing is good.one thing i tried is putting the 2 bar sensor back in and it doesn't knock at all what could be wrong? i know i should be using a scan tool to see how everthing is running but i don't have one right now. so could anyone give me some ideas what else i could look at or what could be wrong with my set -up?
thanks,
sam
92 ty # 0438
sy112
http://www.sytyarchives.com/howto/viewarticle.php?article_name=ignition_tune_up.php&dir=engine
90% of the time knock comes from a bad ignition system in our trucks. have you done the "recommended" tuneup, cause the jiffy lube type usually makes it worse and not better.
and no offense on this, but you really NEED a scan tool on these trucks, it's a requirement. i honestly recommend pulling off the ultimate until you get a scan tool and get the issues worked out. the ultimate will show any weakness in your tune. better to be without the ultimate than rebuilding a motor cause you weren't really ready for it in the first place.
EDIT:
and when you say it doesn't knock at all, are you referring to audible knock? cause audible knock is when the knock is so severe that the ECM can no longer pull enough timing to keep up. if you are not "hearing" any knock with the stock chip and 2 bar I would still bet you are getting knock retard just that your ECM is pulling out a truck load of tiiming. Either way, you keep it up and you will be posting in the Mod/Repair forum in no time to ask about a rebuild.
Please try to get with a local if you have one around and try to get a scan tool on that thing as soon as possible :wink:
InvisiBill
What they said. The ECM will pull out up to ~12° of timing to stop knock. If you're hearing knock, the ECM has already pulled out that 12° and it's still knocking.
For comparison, you're aiming for 0. 3 is generally pretty good if that's the best you can get.
Get a scantool now or plan on doing a rebuild soon.
typhoon92
i have changed the fuel filter and pump with the walbro high presure pump.also have new cap and rotor (conrad) ,spark plug wires (taylor) and plugs (ngk). i'll try to get hold of some of the local guys over towards Seattle
thanks,
sam
92 ty # 0438
