http://www.sytyarchives.com/howto/viewarticle.php?article_name=ignition_tune_up.php&dir=engine
90% of the time knock comes from a bad ignition system in our trucks. have you done the "recommended" tuneup, cause the jiffy lube type usually makes it worse and not better.
and no offense on this, but you really NEED a scan tool on these trucks, it's a requirement. i honestly recommend pulling off the ultimate until you get a scan tool and get the issues worked out. the ultimate will show any weakness in your tune. better to be without the ultimate than rebuilding a motor cause you weren't really ready for it in the first place.
EDIT:
and when you say it doesn't knock at all, are you referring to audible knock? cause audible knock is when the knock is so severe that the ECM can no longer pull enough timing to keep up. if you are not "hearing" any knock with the stock chip and 2 bar I would still bet you are getting knock retard just that your ECM is pulling out a truck load of tiiming. Either way, you keep it up and you will be posting in the Mod/Repair forum in no time to ask about a rebuild.
Please try to get with a local if you have one around and try to get a scan tool on that thing as soon as possible :wink:
