Need opinions on Knock
autoaddictions
Ok ive been trying to get my bone stock Sy to run right, So far ive replaced all the vacume lines,plugs .wires, cap, rotor,coil,fuel filter and installed boost controler set to 14psi,rebuilt transand a 2200 stall converter. Did a compression test to be sure things looked ok.
Perfect #s on the compression test 150 psi per cylinders.
Now ive been using Tookys guide to get this thing straitend out but ive been getting stoned at every turn. Yes im talking about knock. Datamaster is showing up to 12* of spark retard I made a few passes at the track and a 14.10@95 is the best i squeeze out.
I can really feel it lay down in 3rd gear untill the conveter locks up at 70mph then it wakes back up and spark retard drops to about 6*.
I dont hear any detonation at all during a wot pass even at 15psi.
I ran a 50/50 mix of unleaded 103 with pump 93 and the knock didnt change. Im thinking it might be false knock, but i cant find anthing loose ofr banging around in the engine compartment.
It will throw a code 43 Esc somtimes but not all the time. Dont seem to differ in performance either way.
I ordered a new GM knock sensor and am going to try that out thursday at the track.
I also will check that the stock chip is seated in the ecu properly as i havent opened it up yet, (Its still taped shut from the factory) Virgin.
Any ideas i missed out on be much help !!
mattw
Re: Need opinions on Knock
Do you see knock and/or do your knock counts increase when you rev the truck in neutral?
-Matt
Flyin Ryan
hated cuz he drives fords
I was thinking this too since the higher octane didn't do anything... check the dp heat shield mine used to run my knock up some and check and make sure the fuel lines and or trans lines aren't tapping on anything
sy#2921
BAMF
I find it a little strange that your knock drops when the TC locks up. Maybe it is something to do with the trans or TC causing false knock.
Have you tried to rev in park trick?
autoaddictions
TwinTurboV8Ty said:
What about the fuel pump?
It has a Walbro and racetronix wire harness dont know how old it it. I did check fuel pressure 42 psi. Has the stock reg on it still.
Tooky
Serious about performance
Frank did you change the torque converter and/or transmission since we last talked??
autoaddictions
Changing the converter tonight! Trans seems to be shifting perfect with the tv cable adjustment. Still knocks the same looks like a saw blade on datamaster. I did install a manual boost controler set to 14 it flatend up the boost, no more roller coaster effect.
Syclone #1721
I LOVE 4UM SUPERSTARS
Just a thought.....my stock syclone with basically the same exact upgrade/maintenance items that you recently installed used to knock pretty good under hard accelereation. And then I changed the intake gaskets and poof, NO KNOCK. I would check to see if its bad.... :2cents:
autoaddictions
Uppers or lowers!! Interesting thought!
Syclone #1721
Lowers....mine was blown clear out. I couldnt even believe it ran as well as it did. WHile it was out, I rebuilt my dist too. If you decide tyo do this and need a hand, I could help you out.
wildphil
I Love My Ty's
I hope GM does not sell you the same part number knock senser that they sold me. It is not the correct one. If it is not the correct knock senser when you start your truck the check engine lite will come on and you will get code 43. I hope this does not happen to you. But it may because the Gm dealer assured me that they gave me the correct part number for our trucks.
sy#2921
BAMF
You bring up a good point Phil. I think we need a reference to the correct part number. I know it took three tries with my dealer to get the correct one
turbodig
Hmmm... got a screen shot or DM file?
This, coupled with your intermittent 43, would point to an ECM/MEMCAL/chip carrier issue.
When do the knock counts go up? In short bursts, or constantly counting?
autoaddictions
Ok ive replaced the Knock sensor and everthing else in the Ign system even the ecu. The stock chip 14 psi of boost base fuel pressure at 42 it knocks 12* retard, 14 psi FP set to 46 it Knocks the same this is all on 100 octane fuel i notice my O2 mv are in the high 900s . Now i decide to try a ATR pit bull strip chip i had laying around from myTY.knock is down to no more than 5* and fuel pressure is at 46 o2 mv are in the high 800s. I notice the leaner condition and bring the FP to 50. Now it knocks more up to 7*. It seems to like it leaner so i try 42psi of Fp and the knock just about disapears o2 mv now in the low 800s to high 700. Does this make any sense to anybody.
Daryl H
I guess there is no easy way to check the gaskets without removal?
The pitbull is rich at WOT. If I had to guess your Fuel pump is on its way out, the higher the pressure the less fuel its able to deliver.
I had a Walbro in my Corvette, the stupid pump died after less than 500 miles and 3 years. The pump dying was the last thing I expected.
