Need Some Help on This (pic included)
SpoolingTurbo6
easy fix
easy fix
The pinion is easy to fix I done mine for about 15 dollars and 2 hrs of time
Take the driveshaft out then the nut on the pinion ,used a pulley puller I think. Then take a screw driver and smack the old pinion seal out. Use a large socket that fits just inside the lip of the new one BE SURE TO DRIVE IT IN STRAIGHT THE FIST WACK! Hope this helps
Tyson
Junior1
NASTE Member
Just waiting on the guy now - I made some offers and I'm letting him brew over the weekend. He's a dealer so naturally he thinks its last one on earth and wants top $$$ for it.
Junior1
NASTE Member
SyTyArchives said:
looks rough for 26,000 miles.
Funny you should say that - the appraisal guy said the same thing
"There is quite heavy rust on some of the suspension components suggesting that it has seen some harsh weather and possibly sat outside in the elements. There are a number of leaks on the underside indicating poor maintenance, and finally the transfer case seems unusually clean when compared to the rest of the drive train components suggesting to me that it may have been worked on or replaced and with this car supposedly only having 27,000 miles on it"
This deal is starting to smell bad, not to mention the guy only came down 1500 on the price
Junior1
NASTE Member
Its listed for $25,500 - he went to $24,000. I offered $20k, he said he paid more for it, but I'm starting to think it might not be worth it, especially with unanswered questions
ItsMyTy
Life is beter at 25 PSI
that pinion seal is pretty common problem
nothing to it, about an hour of labor plus the seal, for a total of about $100 at the dealer
you can fix it yourself, you don't need a torque wrench. you'll need a 32mm socket on a 1/2 drive impact for the nut. you've just gotta mark the pinion and nut so you know how much to tighten the nut when going back together with it. if you screw up the pinion preload (too loose or too tight)and you'll be rebuilding the rear end in no time.
Junior1
NASTE Member
The pinion is no longer an issue. Now its the fact that everything is quite rusty for a truck with 27k and the tranny and transfer case looks brand new. I'm trying to get in touch with the original owner to see what the dealer/stealer is not telling me. I'm just getting an overall bad feeling. While I have no problem paying top dollar, I expect everything to add up correctly, better yet for that money it should be perfect
Boosted
20K seems like an awful lotta money for 12 year old truck. For that money I would expect something pristine. Any doubts at all and I would shy, personally. Isnt there a board member looking to get rid of a nice truck for less?
