Need some tuning help, please ????
just a 6
R.I.P MyClone
I just datalogged my truck during a 0-80 WOT pull. I'm asking for some help in what to look for in the DM during WOT runs? Like Lterm, Sterm, BPW, InjDC, VE or anything else? I been having stumble problems from a slow takeoff at a light or simular, only on very little part throttle. I been playing with my fp and it's now 60psi base, the stumble is much better. Hardly anything but it think i could raise the fp some more. I'm trying to figure out with DM if i'm running rich, lean or perfect. I'm planning of going to a 1/8 track this week but would like to know what to look for in DM when i'm there. I can't send the DM file tonight but i could send it tomorrow morning when i get to work (left internet cable at work). This is the mods i have:
> >Ultimate set on T1-20, but boost not controlled by ECU
> >Speed Pro I-2441 pistons 030
> >3-angle valve seat with back cut valves
> >Polished lower and upper intake runners
> >Everything is port match to gaskets
> >KB Air cleaner
> >Stock turbo and down pipe
> >High flow 2.5" cat 3" mandrel bent exhaust after cat no muffler
> >Adjust fpr set @ 60psi now, and yes it raises with boost (have fp gauge)
> >255 lph HP Walbro pump
> >All new sensors except IAT and knock
> >Clevite 77 bearings (Nascar)
> >NGK Iridium plugs
> >Taylor "409" wires
> >MSD dist
> >15psi wg actuator, no boost control (straight from comp housing to wg)
> >EGR blocked between lower and upper intake
> >Stock injectors (cleaned and flow tested)
> >SAAB 9000 FMIC
> >160 t-stat, stock clutch fan
I'm pulling a max of 6.9* timing and knock count went from 1751 on 0mph to 2695 at 89mph after that i let of the throttle. It started to pull timing at 3925rpm/24mph/1st gear---1.8* to 3600rpm/40mph/second gear----4.6* after that i slowly went down to 0* at 3725rpm/70mph/third gear, then it started to climb again until i let off at 3975rpm/89mph/forth gear i think. Spark retard was 6.9*, i have problem getting in forth due to that valve in the trans that dosen't like WOT shift to forth gear.
O2 is between 930-950 the whole WOT run.
If somebody would like to help and need more info feel free to ask, thanks.
kwick6
What version ultimate you using? You might want to find someone that can tweak it a little for ya. I've always found a lower base FP had less of a stumble off the line. I've only really heard people running the higher FP's when they run a bigger turbo on a stock injector. I'd say you might be reaching a point when the FP is too high for the injector to (open/close) correctly.
Also just noticed something else....what fuel you running with the T1-20 set.
just a 6
R.I.P MyClone
Ultimate v6.................i get more stumble with lower fp. The off the line is only with like 20-30% Throttle, if i give it 50% or more no stumble.
93 pump gas.............Aanybody want to chat about this, feel free to AIM me
Sy769
Cut from one of BG's posts.
****02 millivolt readings
at startup - should be rich/slightly rich (02 is not warmed up, but warms up quickly, and engine needs to be rich at start/warmup)
at idle/cruise once warmed up, you will see 02 values flicker all over, crosscounting across 450mv.
at WOT/full boost, you should see them in the 900-1000 range. I've seen them in the 800s, but for the *most* part, 900s is safe. You need to watch your truck and apply other tuning skills to find out what works best for your truck
****Knock retard - want to see zero, but hardly any trucks see this. A couple degrees during shifts is normal, but ideal is zero, again.
****Integrator
128 is neutral (zero), this will change on the fly a lot once the truck is warmed up and in closed loop. I'd say the normal range is 100-140. Datamaster gives you the option of using S terms (short term fueling trim). 128 is zero, 141 is 10% richer, 115 is 10% leaner, for reference. Crosscounts or xcounts is a running counter of the number of times the 02 readings have crossed 450, going lean, or going rich. This number will overflow at 255 and begin again. At closed loop, this value should be moving pretty fast. It is a good indication of how well your closed loop system is working (or not).
****- Block Learn Memory
This value is an attempt by the computer to try to adjust for long term fueling adjustments, due to engine wear, or anything that may change the fuel needs of the motor. We have only 2 cells in our trucks, open or closed throttle. So you may see your values change when you open or close your throttle. 128 is neutral, once again. I'd say you have some issues that need looking at if you are outside the window of 115-140.
****Timing - you will see 20-30 at idle/cruise, and should see 12-15 at WOT/full boost. Racier chips will push the timing values at WOT to 17-19 possibly.
*****Wastegate duty cycle -
100% is the solenoid is fully closed, 0% is fully open. Think of it this way, at 100%, the ECM is desiring more boost, at 0% the ECM is desiring less boost.
*****AFR target is NOT an air fuel reading. It is a programmed value in the ECM for a fueling multiplier. So at start/warmup, you will see richer AFRs until it is warmed up, when you will see it go to 14.7. Once you go into Power Enrichment mode (you floor it), the AFR will go richer, to 11-12:1 ratios, depending on chip programming, and based off of RPM.
*****IA temp /MAT
20-40 degrees above ambient are typical. You can watch this value increase with heat soak, or if an intercooler pump is dead. EGR will raise air temps as well, usually 40-60 degrees above ambient.
*****EGR stuff -
EGR duty cycle will kick in during light cruise conditions, unless it is disabled in the chip, or not enabled due to other conditions.
*****IAC - 10-30 at idle is about normal. Adjusting the throttle stop can manipulate this value, as you are creating a slight vacuum leak.
*****Battery voltage - 13s are good, at WOT is very important, 13.4+ being very good at WOT. This will have huge effects on performance.
I believe these to be the most important ones.
Watch when trouble spots are occurring, during WOT, during shifts (graph RPM vs MPH), at boost spikes, at knock, at lean spots (02s dip horrendously). Finding correlations is a start for identifying problems, but be sure it is a cause and not a symptom. (I have low 02s because I have lots of knock...) Watch the changes you can make on a datalogger with actual changes to the truck. Make performance logs to document what helped or hurt. Take notes so you learn from your experience and can share, or at least know your truck better
just a 6
R.I.P MyClone
I really appriciate the help from the last 2 posters exactly what i was looking for, but there got to be more people that can help me understand or teach me how to read the DM files? 89 hits and 2 replys..........was up with that?
Tooky
Serious about performance
Swede I can help you, I tried to AIM you like you said but it says you're not online. So next time I'm online you can drop me a message and I will help you with Datamaster if I'm not busy. Send me one of your files I can take a quick look.
FWIW you should see the heinous stumble my truck has leaving stops due to the low (38PSI) fuel pressure I run for my alcohol injection "hack" on the Ultimate w/stock injectors. If I turn the fuel pressure up to 50 my WOT performance sucks (with alcohol) but my driveability improves significantly. I know you aren't spraying alcohol but with the Ultimate chip on my truck I have found that a number of times a compromise had to be made. The only 100% solution is custom chip editing but perhaps your truck can be tuned to run satisfactorily easier than that (maybe a fuel delivery problem that could be remedied by changing fuel filter or running some Chevron Techron injector cleaner though).
