need trouble shooting charts
vortecfiero
im sure search will own me ... (yes I looked :eek:) )
I have the cd and i cant find the trouble shooting charts for "wont start"
injectors wont fire ( i plug a small 12v bulb in one of the 6 injector plugs with the other 5 connected)
ive checked and re checked the harness
i have spark and fuel pump comes on
i have 12v at the injectors (grounding it myself will start the engine momentarily)
i figure the ecm is not switching ground for some reason
i tried a diff chip and ecm
ecm lights check engine light and pump goes on
sytyguy
Moderated User
Re: need trouble shooting charts
Have you verified all main harness grounds to be good and functional? Don't forget the two on the t-stat housing and one on the back of each head.
I'll keep thinking.....
Hood
turbodig
Reference pulses from dissy?
Injector ground at ECM?
Injectors fire pretty easy... you can fire 'em on a desk with an ECM hooked
up to power and dissy pulses.
Later.
Dig
SY2932
Administrator
HTH's
Crimson93Ty
PITA new guy
That's the wrong ignition module though. You kinda gotta look at the regular Sonoma helms book, get the how the ignition module is wired and then kinda plug it in to the syty specific helms book. They are all that way.
vortecfiero
could you elaborate a little more.. is the syty manual wrong ?
i have found the material i need on the cd and the reg 4.3 stuff too..
thanks in advance
vortecfiero
test results
I was led to and followed this chart to the bottom
and ended up on left side...
"ckts 467 and 468 shorted to voltage........."
looking at the test.. ignition on and probeing the plug at c11 and c12
the diagram indicates there SHOULD be votage here from the ignition
switch, through the injectors and down to the ecm plug
.. but the chart says this is wrong??
should i be probeing the ECM ?? at c11 and c12 ?
thanks in advance
