Needing Help Using DataMaster to Diagnose a Problem
Bill Z
My pretty much stock truck with Ultimate chip for stock injectors) starting running poorly. It starts up fine but won’t accelerate quickly. Even in boost, it doesn’t accelerate. However, if I give it throttle very slowly, I can get it up to 65 and 70 MPH. Also, at RPM between 1500 and 2000 it bucks and won’t take any sort of rapped throttle.
I changed the distributor cap and bug, spark plugs and fuel filter with little improvement.
I hooked the truck to DataMaster version 3.4.1 (the default install) and noticed that the ‘Speed’ indicator on Datamaster was all over the place (like teeth on a saw). It is really noticeable when I look at the line graph at the bottom of DataMaster. This was noticed with the ignition on but without the engine running. Of course it wasn’t going anywhere but DataMaster thought it was going 150 MPH then 0 then back up over 100 and again down to 0. The speedometer stayed at 0 the whole time. Didn’t even jump or twitch.
I unplugged the sensor cable from the transmission and still DataMaster thought it was going at a high rate of speed. It would be nice it the truck could actually do stunts like that.
What sensors or signals go together to make DataMaster think it is going at these speeds?
I’m thinking that this is one of my problems with not having acceleration. The computer doesn’t know a reference.
By the way, I get normal voltages at the TPS. From .47V to 4.07 (full throttle). TPS voltage or % doesn’t change when the Speed is jumping all around.
Someone please help.
Re: Needing Help Using DataMaster to Diagnose a Problem
Hey Bill,
I left you a voicemail, im thinking you may have a chip and or ECM problem, i know after i put the new MSD dizzy in my Ty it ran great for several months and then it had trouble starting, i had fuel and spark just wouldnt kick over, i checked all the wiring and a nice smack on the side of the ECM it would fire right up, it would do fine for a few days and then again usually in the morning not want to start, another smack on the ECM and it was back to normal. I bought a new ECM for it, but the crank broke before i got it swaped in. You more than welcome to try it, and i can bring over the autoprom tuner and my laptop and load up a new program and see if it makes any differance over the ultimate chip, that way the ECM and chip you have will be eliminated as possible problems.
The speed thing has got me baffled, so bad ecm or chip is all i can think of.
Bill Z
Mike,
That would be great to try. At this point I'm ready to try most anything. I got any evenings this next week. I can't go any where because my truck is sort of down. I can take the red car for parts and stuff :)
turbodig
Sounds like a bad ECM, a bad pin on the Ultimate, or both. Make sure you have the memcal oriented on the ultimate board correctly, as well.
Bill Z
Yesterday, I removed my Ultimate chip and put the 2 bar MAP back in but didn’t notice a significant difference in performance. I borrowed Hotrodv6’s ECM and still no change.
However, Datamaster doesn’t have the saw tooth graph for the speed anymore but the actual performance trying to go into boost isn’t there.
Unless someone has a different suggestion, tonight I’ll try checking my fuel regulator and replacing all of my injectors. I just happen to have a set of flow tested stock ones.
I am now figuring that I have more than one issue and little by little, I’m eliminating them. The worst problem hasn’t been found.
I still am seeking suggestions.
try going thru the service manual procedure to check out the dizzy, ohm out the pickup and module and also there is a tst procedure for the primary and secondary side of the coil. Doubt thats it but its all i can think of.
I thought the ECM was going to fix it for you.
Just thought id update this for anybody interested, the ECM changed nothing.
Put in the new injectors and runs great, even with the ultimate chip reinstalled.
Bill Z
Well, I thought I had it all figured out. I replaced my injectors and did a trial run. Ran great. So I put it up for the night. Started it up in the morning and ran more crapy than before. I put Datamaster on it and got a max reading on the MSP sensor. I reseated the MAP and the values came down but it still runs crappy. Right now, I have the fuses out of the ecm hoping to start fresh in a little while.
I think I’m fooling myself. There seems to be some intermittent problem. It really gets bad at low RPMs (before 1900). After 1900, it starts to smooth out.
Any ideas? Anyone!
Haven't seen anyone say "check grounds." If this problem started quickly, I'd check the usual suspects; fuel pressure, ign, maybe the TPS, one of the other sensors? Look at the DM readout for manifold pressure & temp, water temp, stuff like that.
Just my :2cents:
Bill Z
Just my :2cents:
Don,
If I send you my DM file, will you help me read it? That would help.
My first post mentioned that I had replaced plugs, cap & rotor. I checked the grounds, TPS, fuel pressure, vacuum and the Positive battery cable (pos for corrosion). Since then, I replaced the ECM, injectors & MAP with little improvement. I also replaced the throttle.
I'm still stumped.
I'm no expert but I'll look at it for you...
Bill Z
I fixed the problem.
All I can say is DUH!!!
The root of the problem was my plug wires. Maybe the real root of my problem was ME. You see, I had installed a set of MSD wires after I had put the Mallory extra shielding over the 2,4,6 wires so they would have extra protection from the down pipe heat. I spent a lot of $s on some great stuff so naturally the wires couldn’t be the problem. I had used these wires for the past 18 months before the problem started.
All of the time and money that I put into the wires and they lasted me twice as long as the cheep wires. It comes out about the same. 2 sets of cheep wires give me the same service time.
I want to think both Mike and Eric for helping me and encouraging me. I didn’t want to dump the truck because I just love these trucks but I was getting frustrated with me not being able to fix it. Plus my wife ragged on me for driving this 13 year old POS (comments like that hurt).
Yup, DM couldn’t help much here but it did help me to clean up some other things that could lead to bigger issues.
I just wanted to bring closure here. Thanks everyone.
turbodig
Curious... do you have your stock heat shields in place around the manifolds?
I've used the Autolite Pro cheapies for years without problem. As you say, they last about as long as the more expensive ones. The braided shielding helps, but you can put that on the cheap wires, too. And use it over and over...
The Powermax cheapies also look to be good ones... they even have the stock-style angled boot for #6.
Later,
Bill Z
Yup. My Ty is stock and I still have the heat shields around the spark plugs. The wires that went bad were # 1 and # 2 plus the coil wire. I ohmed them out. They all look good, no burnt spots, no oil, no swollen boots, no cracks, no cuts, nothing that would make you suspect a wire.
MSD said they would replace the bad wires. I'm going to get a RMA# and send them back. The worst it can cost me is the postage.
After these cheep Borg Warner wires (they gotta be good because they have NASCar all over the box) fail, I'll try your suggested PowerMax cheapies with my Mallory shields.
