nitrous kit
EDDYSY
Hello gentlemen! Who can tell me how safe it is if I put in my Syclone nitrous kit?at moment have install methanol kit and 18 psi boost at 11.2 afr.
MikeRenz
not stock
Re: nitrous kit
it's extremely safe. until you use it. most everyone that has used it has popped head gaskets, likely due to how unevenly the intake distributes air, and it probably ends up unequally distributing the no2 - making tuning it pretty hard.
gnjeff.t
Re: nitrous kit
you mentioned how unevenly the intake distributes air. I have a GN with an RJC Power Plate on it to force more air to the front cylinders. Is there some device used to help envenly distribute the air for the Sy's and Ty's? On the GN's the back cylinders get the most air, making them lean. what cylinders get the most air on the Sy's and Ty's? By looking at the intake it would seem they should be pretty even.
TYHOGG
Re: nitrous kit
i've used lots of nitrous on my stock intake truck with no problems. over boosting killed it this last time.
MikeRenz
not stock
Re: nitrous kit
the front cylinders get the majority. Under boost things work a little differently since everything gets pressurized and the air rushes for any opening it can find, but air flow control is still an issue under boost.
There is no stock intake insertable baffle / channelizing device that i've ever seen or have ever heard of anyone attempting to make. Its still a project that i'd like to take on - designing a stock style intake that more equally distributes air flow...its still on my plate just haven't made any progress on it for a while.
MikeRenz
not stock
Re: nitrous kit
that power plate is a pretty cool idea, but that really seems more like a bandaid than a solution. Although it's obviously the cheapest alternative to try to fix this issue.
Maybe i'll look into this kind of option for syty's.
gnjeff.t
Re: nitrous kit
The Power Plates are designed specifically for each type of intake and plenum. I was able to run about 2 pounds more boost with no other changes. The knock sensor on the GN is right at the back of the motor, right where it would pick up the back 2 cylinders.
MikeRenz
not stock
Re: nitrous kit
the syty's are setup the same way, with the knock sensor behind the distributor.
TYHOGG
Re: nitrous kit
what is your setup like? Where are you introducing the nitrous?
Gm EFI NX Express "wet" kit, nozzle was about 6 inches from the tb on the a/a pipe. The biggest i ever ran was a 30 shot, but holy crap did it make a difference. I might run nitrous again if i increase my turbo size. i've wanted to screw with NX's progressive controller for a while.
http://www.nitrousexpress.com/product-details.php?id=1408
I also toyed around with having a "phenetic" style spacer between the upper and lower made with a spray bar.
EDDYSY
Re: nitrous kit
I will try to run with a shot 50 on my Syclone. I have a challenge to Cherokee sc
Ty92Resto
Re: nitrous kit
did anything ever happen with this? I remember a discussion at the KC Nats back in the 90's basically concluding nitrous was a prescription for a new engine build if compression wasn't backed off. sounds like compression not the issue rather more gasket and air distribution. I have no intentions on adding nitrous but just curious.
Re: nitrous kit
I have a couple of ideas that might be able to be executed with the stock manifold. Would require some machining and then welding to finish it off. It would give even distribution to the front 3 and back 3, although the firing order also comes into play if you are going to be really picky.
I made a rough model of the upper manifold in Solid Works and was planning to do a simulation to see where the air was going. Unfortunately, I don't have the whole sim package so I didn't follow through.
As far as air distribution, DaveP had a post the other day on why he believed the middle cylinders (3 and 4) usually suffer damaged ring lands, blown head gaskets, etc. before the other cylinders. I couldn't find that post in a quick search because he posts so much, but it was interesting. The jist, in his opinion, was that it was more of a problem with the water jacket around 3 and 4 not adequately cooling compared to 1, 2, 5 and 6.
On the topic of using a Wet N2O kit, the upper isn't designed to flow liquid. The combination of nitrous and fuel can cause problems, particularly with uneven flow distribution. In my opinion, go with a dry nitrous kit unless you are going direct port. Then you are injecting right next to the fuel injector bung and can take advantage of the tunability of a wet kit.
SYCLONE#1531
'MOFOFAST
Re: nitrous kit
Edelbrock conversion would be the easy fix!! Thinking of adding a little to mine!
