Matt
Hey guys i was contacted by a fellow sytyer looking for some assistance diagnosing a no boost issue, he can not post yet input appreciated
thanks matt
Matt,
Here is a list of the mods as I know it:
-ACVr boost controller
-Greedy turbo timer
-Applies Technology and Research chip (STG Racing CB-16y6)
-7th Injector INJ-7B Injector Controller (1992) from Applies Technology and Research
-no cat installed
-3 inch exhaust
Missing:
-stock boost conroller
-stock map sensor
-stock MEMCaL
Symptoms:
-No boost
-vehicle doesn't rev over 4k
-no loose cold air side leaks
-no hot side leads
-check all vacuum lines(several times)
Thoughts:
-chip is causing the vehicle not to boost, symptoms consistant with valet mode, but chip data box showing
15 lbs boost street mode
-I even disconnected the boost controller and ran the vacuum line from the turbo to the wastegate, still no boost?
-The vehicle has 112k miles, the engine runs tight.
-No air blowing out of the oil filler cap(when removed and power-braking the vehicle raising boost)
-I have ordered the stock MAP sensor, the blow off valve...
-trying to locate a stock MEMCal
thanks matt
Matt,
-Greedy turbo timer
-no cat installed
-3 inch exhaust
Missing:
-stock map sensor
-stock MEMCaL
Symptoms:
-No boost
-no hot side leads
Thoughts:
