Osmosis
Re: no start
OK, I got it started. I was perplexed to say the least. My Ty always runs amazing with a good tune and steady idle. Initally, I thought I may have not connected a ground wire on the top drivers side bell housing where the transmission bolts to the block. On my Z28 and my corvette, they both had grounds there. I did not remember one being in that spot on the Typhoon, just a wire loom which I installed.
Then, I thought, go back to basics. Spark, Fuel, Air. I had no codes. Pulled all plugs, cleaned them and they looked ok, just a little black due to a rich fuel mixture. Then, the fuel pressure regulator....I FOUND A 3 Prong connector that was disconnected...HENCE the problem...Thank You DAVE!!!!! It was near the fill tube for the transmssion and it must have unplugged during the removal of the transmission. It was difficult to see in all the mess of wires behind the FPR & distributer. Anyway, I found it and she is purring like a kitten in the garage right now
Thank you all for the help :tup:
