Re: Noob wideband questions
vortecfiero said:
With Digs code changes made, is it still necessary to use a Techedge like device if you don't need
a display read out ? can you just use Datamaster?
I'm guessing, either way, with the code changes the ECM sees a broader range of values
and which in turn can indicate through various terms BLM etc. where you are with your AFR ?
While you don't have to have a display, you do have to have a "box" to control the WB o2 sensor. The heater circuit on the WB needs to be current controlled to maintain temp, and the current pump circuit is different from what the stock ECM o2 circuitry utilizes.
From there, the WB code takes the voltage the "box" outputs, and injects that data into the ALDL datastream for Datamaster/Turbolink/Diacom/Freescan or whatever you're using to collect data. It's not scantool specific.
The only "gotcha", if you call it that, is that each WB "box" is different in the voltage to AFR curve that they produce. The Techedge and the DIY
Wbs are pretty close to each other, but the FJO and PLX units are different.
Patch files will need to be developed for the new applications.
There's really no comparison to having the data integrated with the DM data vs. just trying to read a display. It's extreeeemly difficult to tune when you can't correllate RPM to MAP to AFR. The higher-end WB boxes have datalogging capabilities to do just that if you don't have a patched binary.
Later,
Dig
