No pics , but you cant go by what may or may not be needed by others . Your going to have to lay in your rotating assembly and spin it and take note of where the suspect areas are . You may get lucky and only need to clearance the oil pan .
Just remember every block is different due to core shift. This gives you an idea where it will be close. (pictured: Eagle Rods, JE Pistons on Syclone block clearanced for rods.)
