Re: oil pressure gauge
Got around to fixing the needle that bounced around.
Phil- I went with your approach and used a very small piece of wire, put a small J hook on the end so there is some room to tweak it and get an ability to flip/spin/snag. Lucky me I looked over the cluster before I did anything dumb ( like pry at the plastic) I was able to find a small crack in plastic located at the bottom of cluster where I was able to snake in my little micro wire. The funny thing is it was like PEGGED it did not work how I thought it was going to and seemed like it was spring loaded on the return as it slammed down to the rest. All the other gauges kinda float if you know what I mean.
Must be the mechanicals of it.
I looked at the last link provided from blacke and I am now seeing I can separate the lenses from back with the perimiter screw's located on the back. I eventually am going to need to crack it in half because @ some point when the typhoon had a " pretty hard hit" I believe the speed odometer center cover thing flew off. I found it hiding wedged out of sight.
Also I am pretty sure my needle flipped because the truck hit a Crater in the road..
And... Bent one of my syclone wheels
:tdown:
