one problem to the next really rich
littleblackpsycho
I fixed my backfiring problem by getting a different distributer cap so it runs pretty smooth.
but i forgot about my problem from last year of not being able to get my idle afr past 11. When I try to adjust it through f29c it will fluctuate about .5 either way, and when I adjust the base pulse constant it doesn't affect it at all. I tried every bin I could find on the internet, all the ones that I made and that people gave me. and even all the ultimate programs. So I tore off the 50 lbers and put the stockers back in and tried the ultimate stock injector bins and same problem, I tried a 50lb bin and it made no difference stayed right around low 10s. Then I switched out map sencor and disconected tunerpro put the stock chip back in it and it would barely stay running but I let it run so I could get a plug read and they are really black. I'm stumped.
Re: one problem to the next really rich
If it has been real rich for awhile it could have messed with the WB o2 also.
turbodig
Couple things:
What wideband do you have?
You mentioned "downloading every bin you could find" ... if the bin isn't patched for the wideband you're using, it won't read AFR properly.
If the wideband you're using is programmable, and isn't programmed properly, it'll do what you describe.
littleblackpsycho
I have innovate lc-1, I have the patch for the bins from your site, I was also checking the plugs alot so I know it was really rich. This morning I redid all the engine grounds and made sure they were all clean and didn't help at all, I remember programing my wideband to the lm-1 stats on digware because there weren't ones for the lc-1.
